help me.. i have fuel in the engine oil..
Old Dec 10, 2001 | 11:57 PM
wdyno's Avatar
New User
Default help me.. i have fuel in the engine oil..
my car doesnt start up.. and i have tried everything.. theres fuel in the oil.. and alot of it.... what does this mean??? bent valves?? detonation? cracked pistons?? and theres no oil in the coolant or gas in the coolant.... just in the oil.. i drained the oil and theres lots of gasoline in there.. anybody help me?
Old Dec 11, 2001 | 01:07 AM
Perfectionist's Avatar
Default Re: help me.. i have fuel in the engine oil.. (wdyno)
Sounds like a majorly stuck open injector. If that's the case you will have to determine if it's mechanically stuck or if the ECU is holding it open.
Old Dec 11, 2001 | 09:08 AM
brian b's Avatar
New User
could be an exploded aem fpr.. (its possible any fpr could do it, but lots of people have had the aem die) check the vac line on the top of the fpr for fuel
Old Dec 11, 2001 | 09:26 AM
civicturbo's Avatar
Default Re: help me.. i have fuel in the engine oil.. (Perfectionist)
Old Dec 11, 2001 | 10:18 AM
Greyout's Avatar
Default Re: help me.. i have fuel in the engine oil.. (civicturbo)
check the compression also
Old Dec 11, 2001 | 10:23 AM
wdyno's Avatar
New User
i have a stock fpr.... and i dont think its the ecu cuz ive swapped out the ecu and tried to start the car.... well i did a compression test and it came out in the 170s for all cylinders.... but the problem is dat it doesnt crank all the way when i try to start it.... it cranks for a bit then just dies.. so i cant tell it these compression tests are accurate.. theres lots and lots of gas in the oil... i can smell and see it... when i drained the oil... how can u test to see if the injectors are bad?
Old Dec 11, 2001 | 04:20 PM
fsarfino's Avatar
I would also agree with the stuck injector be careful and do not try to start it anymore until injector is fixed as it will wash all the oil off of your cylinder walls and that would not be good
zach53
Feb 28, 2012 03:05 PM
JDMb18c1HATCH
32
Aug 5, 2010 08:59 PM
SRd240sx
Dec 25, 2005 03:08 PM
siis2fast
Jun 3, 2004 10:12 PM
smeister
Oct 1, 2002 03:22 AM
