EG suspension In EF
Old Sep 21, 2004 | 03:08 PM
JDMef_typeR's Avatar
Default EG suspension In EF
Will suspension from an EG(92-95) fit in a EF(88-91) car?
i am interested in the OMNI POWER true coilovers and there is no application ffor ef's and there isn't supposed to be for a while.
Is it possible to put the EG suspension in with little-no mods?
Thanks
Matt
Old Sep 21, 2004 | 03:11 PM
WWDTrackRacer's Avatar
New User
Default I have done something similar
Running DC2 JIC coilovers in my ED6.
You need the EG/DC front forks to make it work.
You may run into problems in the rear. I think the rear shocks
have less travel or are a taller physical package. You may find
yourself bottoming the rear shocks.
Lowering the car will cause you to run into more problems.
Old Sep 21, 2004 | 03:12 PM
EL Vap133's Avatar
Default Re: EG suspension In EF (JDMef_typeR)
I would not recommend it.
Old Sep 21, 2004 | 03:20 PM
SuperSteve737's Avatar
When I had my EG, I tried to put on my buddy's EF suspension, but I needed to use the EF front forks. I assume it would work, but I believe it will actually raise it.
Old Sep 21, 2004 | 03:49 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (SuperSteve737)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">When I had my EG, I tried to put on my buddy's EF suspension, but I needed to use the EF front forks. I assume it would work, but I believe it will actually raise it.</TD></TR></TABLE>
Putting the ED/EF suspension on an EG will most definitely lower it.
I tried putting a stock EG strut with fork on my ED and it would have raised it... a LOT. I couldn't even get the strut in there because there wasn't enough room.
With adjustable ride height coilovers it could be done.
Not sure on the rears though.
Old Sep 21, 2004 | 04:02 PM
d357r0y's Avatar
I have EG Koni SP3s on my EF. Zero problems.
As has already been said, you'll have to trade out your forks.
Old Sep 21, 2004 | 04:04 PM
Steve91's Avatar
Default Re: EG suspension In EF (d357r0y)
It's the front shocks on the EG that are longer than the EF's. The diameter of the fork opening is larger too on the EG
Old Sep 21, 2004 | 04:07 PM
sohcfreak's Avatar
i found out that jhpusa.com sells them for the ef..though this will help...i wanted to get some but dont have the scrills..!!
Old Sep 22, 2004 | 11:35 AM
jhpusa sells them, but omnipower doesn't make them? i contacted omnipower through their site, but they have not gotten back to me.
anyways, so the rears and fronts are BOTH longer than ef's? here comes a visit to the junkyard to actually see if they fit...if i do, i will take pics
Old Sep 22, 2004 | 12:00 PM
CRX T-Si's Avatar
Default Re: (JDMef_typeR)
EG front shocks & EG rears are a bit longer(about 1.5"-2") then EF ones, so you will bottom out the shocks.
If your broke then go ahead and use it but don't expect it to last or have the best ride feel.
LuckyJDM
Mar 18, 2014 09:34 PM
Htounndea
Aug 26, 2011 02:02 PM
thenick
May 24, 2005 06:40 AM
loid
11
Oct 12, 2004 11:45 AM
SiccMonkey
Oct 6, 2004 03:54 AM
