1 inch throttle body
Old Sep 21, 2004 | 03:04 PM
lighteyedhulk's Avatar
Default 1 inch throttle body
car revs up and down eractically in park after reving engine after installing 1 inch throttle body
Old Sep 21, 2004 | 03:09 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: 1 inch throttle body (lighteyedhulk)
I think I speak for everyone when i say: what the **** are you talking about?
you need to be alot more detailed about what you did. if you really installed a 1" tb, then I think I know why you're having problems.
Old Sep 21, 2004 | 03:25 PM
after installing 1" throttle body spacer engine revs up and down in park on its own
Old Sep 21, 2004 | 03:35 PM
Bantam's Avatar
define "revs up and down"
does that mean that idle is irradic? what rpm range is it revving itself to?
did you leave any vacuum lines loose? did you use a gasket when you installed it?
you'd have to show pictures of what you did for me to be any help. start by posting your car's year and model, and any details you have about it and maybe one of the other accord guys can help.
Old Sep 21, 2004 | 03:37 PM
Default Re: 1 inch throttle body (tharptroy)
1000 to 2000 up and down untill i put it in gear or step on the gas and take my foot off slowly
Old Sep 21, 2004 | 03:39 PM
Bantam's Avatar
did you use a gasket? did you reconnect all vacuum lines? did you adjust the throttle cable? and what year/specific model is your accord?
Old Sep 21, 2004 | 03:48 PM
accord 94 4cyl 16 valve used both gaskets atached all vacumn lines
Modified by lighteyedhulk at 5:07 PM 9/21/2004
Old Sep 21, 2004 | 04:12 PM
jnet's Avatar
i dont know about the new throttle body...but i know when your idle is unstable you should probably clean your injectors.
Old Sep 22, 2004 | 03:15 AM
Steed77's Avatar
Default Re: 1 inch throttle body (jnet)
It sounds like a vacuum leak to me. Re-check your lines and make shure you installed a gasket on both sides of your spacer.
Old Sep 22, 2004 | 04:02 AM
Monkey Fing a Coconut's Avatar
Default Re: 1 inch throttle body (SilverGhost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverGhost &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like a vacuum leak to me</TD></TR></TABLE>
Old Sep 22, 2004 | 07:18 AM
ChicoAccord2001's Avatar
Default Re: 1 inch throttle body (twistedbydezign)
Or go back to stock because it will still be slow after that mod
Old Sep 22, 2004 | 09:33 AM
Toxygene's Avatar
From: Long Beach, California, United States of America
Default Re: 1 inch throttle body (ChicoAccord2001)
Well when you disconnected everything did you check to make sure tha you reconnected all the vacum lines correctly? Cause just because you connected them doesn't mean they're in the right places. Also, I'm not familiar with the way the car meters the incoming air but do you think you could have either damaged the Mass Airflow meter or the like or the Throttle position sensor? Just a thought?
99turboaccord
Mar 29, 2019 01:01 PM
ColeCooper90
Mar 9, 2018 10:20 AM
sween16
Oct 22, 2012 04:42 PM
ThrowdownPerfor
Feb 23, 2011 09:01 AM
cflagg
Jun 12, 2008 06:15 AM
