i need some help making mid range power on gsr
I'm planning on going for more mid range power. My car is a daily driver and thats wher i spend most of my time in the powerband. My goal for the motor is around 190 hp with great mid range power. The motor is a jdm gsr and I allready decided on the BC III+, cams but alittle confuesed on some other stuff.
Lets start with the intake manifold. I know the stock gsr IM had two sets of runners whicg gives it good low-to-mid range, but would i be better off going to a single stage IM? Or even ITBs? i could also port out the stock IM to retain the dbl. stage runners. Also what size Throttlebody would be best...i was thinking about a type-r or maybe a fer mm over...but im still not sure.
As far as the header I have a DC 4-1 with the 2.5 flange, but i heard a 4-2-1 is better. so i was planning on the apexi header with a 2.5 flange. Has anyone had any bad experences with one.
okay, one last thing. the motor comes stock woth a 10.6:1 comppresion ratio. i wanted to either use some flat faced valves or a two layer head gasket to raise the compression...maybe both. would this be a good idea for what i am trying to do?
Thanks for all the help in advanced
90teg
Feb 6, 2006 07:57 PM
boostedeghatch
May 10, 2004 07:12 AM
