::conversion harness:: service signal help
ok so i hooked up my obd0-obd1 conversion harness but there is one wire i cant seem to find in my 89REX??? and that is the <U>service signal help </U>!!!! please help someone???? WHERE DOES THE YELLOW WIRE PLUG INTO????
https://honda-tech.com/zerothread?id=681461
SVE...i got it from TOM...but there is the link...check it out! still need help
still waiting for some answers, i have search but i always keep coming up with nothin...but imma keep on seaching...**** this last wire!!!!
Wow! I see what you mean, I only buy(wiring) products from the guy in my sig very simple, easy to follow directions.
Are you sure that isn't the wire that you hook to a toggle to be able to see your check engine "flashes" through the CEL?
Phil
Phil
i have the same haerness and my yellow is for your check engine "flashes" through the CEL?
just hooked it to a toggle wsitch and whenever light comes on i flip the switch and read the codes
or does it actualy have a plug at the end of it or is ity just a wire if just a wire then its for check engine but if a plug it depends on what motor you have iat < some dont need
thanks man i got ya...so my check engine light wrks then...hmmm cuz i thought that yellow wire was for my check engiine light to wrk...i guess it wrks then, thanks again!
I thought that was what it was for. Without it you can't read your CEL flashes(obd1 doesn't have the window w/ the red light).
Phil
Phil
.Hookedonhatch.
Oct 18, 2007 04:53 PM
