H22 acting weird
Today while i was driving the car died when it hit Vtec. It would not start again untill reset the ECU. I drove it and the same thing happened again.
I am running a p72 ECU, so I replaced it with the stock P13 and it ran but when it was supposed to hit Vtec it stumbled, then kept going without Vtec.
I am throwing a code for IACV, but I was throwing that anyways. I am also throwing an oxygen sensor and sometimes a fuel injector code, but sometimes i dont throw any codes at all. What the hells going on? What exactly is "limp mode" and what would cause it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22rexguy »</TD></TR><TR><TD CLASS="quote"> What exactly is "limp mode" and what would cause it?</TD></TR></TABLE>
"Limp" mode is your cars "Safe Mode"... the ECU will reduce the fuel cut/redline to 6800, and prohibit VTEC from engaging. "Limp" mode is caused by most error codes that end up in a CEL. Read the codes and fix what needs fixing, then reset your ECU.
I forgot to mention that this H22 is in a CRX. I didn't do the swap so im having some trouble trying to fix some of this stuff. Any suggestions on how to test the iacv? It clicks when I put power to one wire and ground the other. There is no voltage going to the blue/black wire, but there is to the yellow, and there is continuity between the plug and the ECU. When I plug in the IACV I hear a hum for a few seconds. The car wont run with it unplugged. Is there any way to test the valve itself?
Prelude Styl
Mar 20, 2004 08:13 PM
satan_srv
Oct 8, 2002 10:03 AM
