EXPERT ADVICE NEEDED on TIMING BELT look at my pic
Old Sep 21, 2004 | 11:26 AM
gogordo's Avatar
Default EXPERT ADVICE NEEDED on TIMING BELT look at my pic
Alright, here is the deal:
I have 123,000 miles on my 94 LS and I don't know if my timing belt was replaced or not.
I opened up the valve cover and inspected it. Here is the pic:
How does it look to anyone with experience? Your advice will be greatly appreciated!
Old Sep 21, 2004 | 11:51 AM
G-bonic's Avatar
Hijacked
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (gogordo)
with 123,000 miles u talkin about, i wont even think twice if i should change it or not.. ill change it right away to make sure, safe, and save ur engine... not even that much to change it... so dont hesitate to change it
Old Sep 21, 2004 | 11:57 AM
evil_schmevil
Guest
Posts: n/a
that timing belt looks fine to me, but look inside the grooves between the teeth and see if there are any cracks.
Also I thought PR3 indicated a b16 cam gear, you got a head swap or something?
Old Sep 21, 2004 | 12:03 PM
teg92's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (evil_schmevil)
all cam gears I've seen say PR3...
and to me it looks like that timing belt should be changed.
Old Sep 21, 2004 | 12:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil_schmevil &raquo;</TD></TR><TR><TD CLASS="quote">that timing belt looks fine to me, but look inside the grooves between the teeth and see if there are any cracks.
Also I thought PR3 indicated a b16 cam gear, you got a head swap or something?</TD></TR></TABLE>
it's definitely a non-VTEC head, looking at the background of that pic.
Old Sep 21, 2004 | 01:33 PM
jojoforhelp's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (PatrickGSR94)
Theres no point in looking at the belt. You know the car has 123k on it and it should have been changed at 90k or earlier. Why chance it??
Old Sep 21, 2004 | 02:30 PM
willyfingerz's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (jojoforhelp)
Not sure how to link it but this helped me out http://www.babcox.com/editorial/us/us100024.htm
Old Sep 21, 2004 | 04:39 PM
95TEG's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (willyfingerz)
How much can one expect to pay for the 90K service (belt, water pump, etc). I am at 75K now, but live in AZ where its hella hot so I may want to get it done soon. Whats a good price to pay?
Old Sep 21, 2004 | 06:33 PM
93lsd's Avatar
either way of what the pic looks like would you rather a maybe $65.00 t-belt break and cost you a good runing motor.
Old Sep 21, 2004 | 07:18 PM
dFreezy's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">
and to me it looks like that timing belt should be changed.</TD></TR></TABLE>
just curious, whats your reasoning?
Old Sep 21, 2004 | 07:30 PM
mr.beeks's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">
just curious, whats your reasoning?</TD></TR></TABLE>
is like playing russian rulete
a simple fix now could cost you less than a bent valve
Old Sep 21, 2004 | 09:05 PM
teg92's Avatar
The white discolored areas above the teeth in certain areas would concern me if I was playing "russian roulette".
Old Sep 21, 2004 | 09:50 PM
SwedBoy2999's Avatar
As people have already stated, just change the belt for same reason you change your oil every 3000 miles, you need to change your timing belt every 90,000 miles... why risk it....be sensible and don't shoot yourself in the foot.
Old Sep 21, 2004 | 10:10 PM
jDMJeRk's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">
exactly.... youll soon enough have to change it.. better be safe then sorry
and i can too see visual wear.. (good pic though for discusion)
Old Sep 21, 2004 | 11:42 PM
Stewie's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (jdmjerk)
It's really hard to tell the condition of a timing belt just by looking at it. I did that once and I thought the belt was good. Guess what happened.
It's really not that hard to change and a new belt only cost $60 or so.
Old Sep 22, 2004 | 12:39 AM
95GSRsedan's Avatar
I had replaced my timing belt at 90k miles, but while i was at it, I replaced all my other belts,.... alternator, power steering, etc.... and i also replaced my water pump. It's better to be safe then sorry. I did all this for around 110 bucks, a friend and I did it ourselves
Old Sep 22, 2004 | 03:29 AM
DAsix's Avatar
when in doubt replace it.
Old Sep 22, 2004 | 06:11 AM
Alexander's Avatar
Default Re: (DAsix)
Hey, thanks for reminding me... Have to order a belt, water pump, etc
Old Sep 22, 2004 | 07:01 AM
Xumarius's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (SwedBoy2999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwedBoy2999 &raquo;</TD></TR><TR><TD CLASS="quote">As people have already stated, just change the belt for same reason you change your oil every 3000 miles, you need to change your timing belt every 90,000 miles... why risk it....be sensible and don't shoot yourself in the foot.</TD></TR></TABLE>
couldnt have said it better
Old Sep 22, 2004 | 07:32 AM
ponytd's Avatar
Default Re: EXPERT ADVICE NEEDED on TIMING BELT look at my pic (Xumarius)
i got my timing belt at the dealership here and it was only $30 if i am not mistaken maybe $40. now i just need to put it in
Old Sep 22, 2004 | 07:42 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">either way of what the pic looks like would you rather a maybe $65.00 t-belt break and cost you a good runing motor.</TD></TR></TABLE>
A few people have said this. "Not too much", "A cheap fix", etc. Many people don't know how to replace their own belts. This can cost upwards of $600-700 for someone to do it.
Just wondering, if there's a way to contact the previous owner? Ask him, or even take a look at his work receipts?
Old Sep 22, 2004 | 10:15 AM
Honda Logic's Avatar
Default Re: (shamoo)
the belt looks ok...
Old Sep 22, 2004 | 11:53 AM
rovigian's Avatar
Default Re: (Honda Logic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Logic &raquo;</TD></TR><TR><TD CLASS="quote">the belt looks ok...</TD></TR></TABLE>
I second that, it looks like it had been changed around the 90k mile mark. I wouldn't bother with it until around 160k miles.
Old Sep 22, 2004 | 03:15 PM
bluecivic107's Avatar
The timing appears to be good. However, WATERPUMP usually goes bad @ 120,000 miles. Suggeest doing a Timing Belt Service, which includes:
-Timing Belt
-WaterPump
-Accessory Belts
-Crank/Balance Seals
GOOD LUCK
louevilhatch
Sep 11, 2007 05:48 PM
m_cough
May 22, 2007 07:50 PM
AnAccordIsForever
Mar 12, 2007 02:55 PM
bb_one
Jul 7, 2006 09:20 AM
TurboEM1
Apr 30, 2006 11:31 AM
