Burns Stainless/ Saturn Motorsports Turbo Manifold
Old Sep 21, 2004 | 10:08 AM
Ekasey's Avatar
Default Burns Stainless/ Saturn Motorsports Turbo Manifold
This header took us all of two days to complete definitely not what we wanted but the best we could do in the midst of a thrash!
Disclaimer: This is not an advertisement these products are for race use only!!!!!!
*hehehehe so i don't get in trouble this time*
Old Sep 21, 2004 | 10:14 AM
ELSpool's Avatar
wow, very nice! Quick newb question, where your bends meet the collector, I noticed a few times that they use some type of welded bar from collector to bend, same thing as to keep IC pipping from popping off. Why is that there?
Old Sep 21, 2004 | 10:15 AM
DIRep972's Avatar
Smarter than you
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (eLusive ek4)
Does the turbo stick up out of the hood? Also, is that wastegate going get enough of the flow/flow enough so you don't get boost spiking?
Old Sep 21, 2004 | 10:21 AM
Ekasey's Avatar
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (DIRep972)
It will get more then enou flow the wastegate is routed properly.
The manifold is for a sand rail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">wow, very nice! Quick newb question, where your bends meet the collector, I noticed a few times that they use some type of welded bar from collector to bend, same thing as to keep IC pipping from popping off. Why is that there?</TD></TR></TABLE>
Those are tabs with bolt's through them to hold the collector solid
Old Sep 21, 2004 | 10:24 AM
eHoward's Avatar
Thats one of the best placed wastegates I have ever seen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Also, is that wastegate going get enough of the flow/flow enough so you don't get boost spiking?</TD></TR></TABLE>
Old Sep 21, 2004 | 10:27 AM
DIRep972's Avatar
Smarter than you
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (eHoward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eHoward &raquo;</TD></TR><TR><TD CLASS="quote">Thats one of the best placed wastegates I have ever seen.
yeh, the location looks fine. I just thought the piping to the wastegate and the wastegate looked a lil small in comparison w/ the size of the turbo. maybe I am too used to seeing turbo's like that on methanol set ups, with two huge wastegates so that they don't boost spike.
Old Sep 21, 2004 | 10:32 AM
m R g S r's Avatar
Well, the inlet on the wastegate probally isn't much larger in diameter than the piping is (if any at all). that downpipe (or uppipe? lol) is sick. 4"?
Old Sep 21, 2004 | 10:33 AM
Joseph Davis's Avatar
Yup yup. That's definitely one of the better designed manifolds I've seen... split scroll + paired cylinders help a la Bucci just as much as the merge collectors and thoughtful wastegate placement.
Old Sep 21, 2004 | 10:35 AM
Ekasey's Avatar
The wastegate only needs to vent as muhc boost as your not going to use
MY choice would have been a tial personally and thanks!
Old Sep 21, 2004 | 11:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">The wastegate only needs to vent as muhc boost as your not going to use</TD></TR></TABLE>
Incorrect, wastegates do not vent boost, and as small as you can run without getting boost creep is not ideal. Wastegates are a wonderful method of bleeding off unneeded manifold pressure to increase VE, scavenging, and knock limit. It takes a lot of pressure to spool the turbo, and not much to maintain a certain flow. Sure, you pick up a big pressure drop using a larger turbine, but you can improve upon it with proper wastegate positioning + size.
Old Sep 21, 2004 | 11:03 AM
This One's Avatar
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (J. Davis)
Manifold Looks good, wastegate
Old Sep 21, 2004 | 11:04 AM
Ekasey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Incorrect, wastegates do not vent boost, and as small as you can run without getting boost creep is not ideal. Wastegates are a wonderful method of bleeding off unneeded manifold pressure to increase VE, scavenging, and knock limit. It takes a lot of pressure to spool the turbo, and not much to maintain a certain flow. Sure, you pick up a big pressure drop using a larger turbine, but you can improve upon it with proper wastegate positioning + size.</TD></TR></TABLE>
ok then let me correct myself mr over assuming.
Wastegates vent exhaust pressure to reduce the amount of boost pressure produced by the turbo charger unit.
I never said as small as possible without getting creep was ideal we didn't choose the wastegate sizing. As stated before i would have chosen a different wastegate myself.
Are you stating the waste gate is positioned incorrectly? not trying to be standoffish just asking the question
blundar's Avatar
all I gotta say is Mad Max / superchargers look out! That turbocharger sticking out of your hood will get mad ladies!
Old Sep 21, 2004 | 11:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Are you stating the waste gate is positioned incorrectly? not trying to be standoffish just asking the question</TD></TR></TABLE>
Nope, I think the positioning looks pretty good, myself. I'd just go bigger, or run twins is all.
Old Sep 21, 2004 | 12:41 PM
rioninja's Avatar
And if the queen had *****, she'd be the king
Old Sep 21, 2004 | 01:16 PM
CRX T-Si's Avatar
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (rioninja)
It's it just me or does no one see that the manifold goes upwards, like thru the hood.
How the hell is anyone suppose to use that on a race car or street car???
I don't get it, looks nice but how about the function wise part?? how will it fit under the hood??
Old Sep 21, 2004 | 01:22 PM
DIRep972's Avatar
Smarter than you
Default Re: Burns Stainless/ Saturn Motorsports Turbo Manifold (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">It's it just me or does no one see that the manifold goes upwards, like thru the hood.
Old Sep 21, 2004 | 02:01 PM
CRX T-Si's Avatar
oops, my bad.
Being kind of tired from the Nopi thing and I guess I am still half awake.
Old Sep 21, 2004 | 02:07 PM
.nate's Avatar
wow thats badass
Old Sep 21, 2004 | 02:18 PM
Ri5e's Avatar
Default Re: (.nate)
Cool manifold
Old Sep 21, 2004 | 02:33 PM
SiRkid's Avatar
Default Re: (BG Boost)
very nice looking. Very good pictures too! nice to see all the detail
Old Sep 21, 2004 | 02:54 PM
Ekasey's Avatar
Default Re: (SiRkid)
Thanks guys your reinforcement helps us grow into the import scene more and more!!!!!
Old Sep 21, 2004 | 09:00 PM
.dave's Avatar
i HAS questions ?
Default Re: (eLusive ek4)
What gauge is that/are you going to brace the turbo?
Oh yeah nice job by the way.
Old Sep 21, 2004 | 10:04 PM
Ekasey's Avatar
Default Re: (dave.g)
Dave that is 16. ga and yes of course we are going to brace/support the turbo, because that is the proper way to do it.
Old Sep 21, 2004 | 11:36 PM
@ries's Avatar
Those welds are just gorgeous! All I can say is overall... SKEET SKEET SKEET!!!
