rebuilding b18b piston question?
Old Sep 21, 2004 | 06:42 AM
CUL8RI1's Avatar
Default rebuilding b18b piston question?
Ok im gonna do a rebuild this winter and I need some info on pistons. I'd like to get OEM pistons with higher cr, so which ones to get i'm not sure? Keep in mind I have all the bolt on's and 62404 cams. The head will get done as well. Would PCT pistons be too much compression? Also has anyone used total seal rings? Is it true that they don't need as much break in? or should I stick to OEM rings?
Old Sep 21, 2004 | 07:03 AM
Steak84SS's Avatar
Default Re: rebuilding b18b piston question? (CUL8RI1)
So far I've installed Wiseco 9.5:1 forged pistons and Eagle forged rods. The cylinders were bored .020 over. BUT, the car hasn't been started yet. Should be a good running engine though. I've also done Street PNP, Crower Stage II cams, Crower springs and titanium retainers, re-cut valves, decked block, decked head about .012, Type R oil pump.....bunch of other stuff. DAMN I can't wait to fire that thing. She should be back on all 4 wheels after this friday. I'll let ya know how she runs......still need some parts though. Engine finally sittin' in the bay again.
Old Sep 21, 2004 | 12:00 PM
CUL8RI1's Avatar
BUMP...
Old Sep 21, 2004 | 12:03 PM
evil_schmevil
Guest
Posts: n/a
total seals have a shitty reputation around here, check the FI forum.
Also, I believe the b16 pistons from a del Sol Si will raise your compression to 10.5
I assume you intend on staying NA?
Old Sep 21, 2004 | 12:15 PM
patmcd's Avatar
Any particular reason you want to stay with OEM? There are some good aftermarket pistons out there.
Old Sep 22, 2004 | 05:19 AM
CUL8RI1's Avatar
Default Re: rebuilding b18b piston question? (patmcd)
I trust oem quality more than I trust aftermarket.
Yeah I plan to stay n/a, so what rings are good to get? and why do people hate total seals?
Old Sep 22, 2004 | 05:30 AM
Kendall's Avatar
Honestly, the best option would be to upgrade to ITR pistons (US or JDM depending upon exactly what you want your compression to be). They won't have crazy high compression like the PCT's will, and won't offer as much compression as the B16 pistons, however they are coated to resist heat better, and even more compression can be found with thinner headgaskets and milling.
Old Sep 22, 2004 | 06:08 AM
Fleas_Ef's Avatar
OEM ITR pistons is what u want...pm sent cause i have some brand new in box with rings/wrist pins
chriscool888
May 9, 2012 07:24 AM
egkingfl
Aug 31, 2009 09:36 PM
snowblind7x
Jul 9, 2006 09:06 PM
MEANB18
Oct 15, 2003 09:10 PM
1hotintegra
Jul 16, 2002 05:03 PM
