Suspension Questions
does anyone know where i can find some info about suspension in general online also im going to do a 1.5 drop using KYB AGX shocks and anybrand coilovers i was wondering if doing front and rear strut bars front and rear lower tie bars and front and rear anti sway bars would be most benificial or if i should'nt do them all or what lemme know guys i dont know if any of this would be working against each other or anything.
well suspension is relative to what you plan on doing with the car........
sway bars:bigger rear only....... FWD cars come from the factory with understeer built in, a larger front bar will only increase understeer
strut bars: helps rotate weight transfer from side to side instead of flex of the chassis
suspension:this totally depends on what you want from the car
looks:cheaper setup where you don't really worry about spring rates or complex shock/strut setups
performance:generally more expensive setup where you need to consider spring rates the present set-up of the car and your driving style and the shocks and struts are usually fully adjustable and race valved for higher spring rates
lower tie bars I am not familiar with, but my setup with front strut bar and rear sway bar with a performance built suspension allows me to have one of the most fun track cars out there
I can get my car to do whatever I want it to and handles like a dream
What lower tie is that ?
Is that a ST sway bar ? Did you have problem installing it ?
I have a ST sway bar sitting in my room and haven't got change to install it yet.
I'm planning to install it myself. Can you give directions ?
Thanks
me too..... i am actually going to look into the lower rear
does it help your rotate more in the rear? reduce understeer?
back
Yeah, I was about to say, that sorta somewhat looks like my Civic, or an Integra, but everything looks a about 5% larger. That's gotta be a Prelude.
no its not an accord im asking question about suspension stuff that i do not have yet i wouldnt ask if it does any good after i put it on. i think that is a Teg since it was posted in teg forum
slowteg550
Suspension & Brakes
13
Jan 17, 2006 04:29 AM
FF DRFT
28
Aug 20, 2004 11:08 PM
