What is a good ajustable control arm.
I think K-Mac sells a replaceable upper control arm baring that is adjustable (camber/caster). You just have to press the old one out and put in the new one.
Yeah, there are aftermarket ball-joints for camber & caster (SPC comes to mind), but for an actual replacement control arm you'd have to go OEM or custom.
If you've got a rattle, I'd try and troubleshoot it more precisely before you go in and start replacing parts. That gets expensive real quick. Check all the nuts & bolts for starters, and then inspect all the misc. bushings.
roryss024
Jul 20, 2015 07:24 AM
jonesEK
Suspension & Brakes
Nov 22, 2010 03:51 PM
