Fuel Mix too lean
Old Sep 21, 2004 | 04:55 AM
Mike1486's Avatar
Default Fuel Mix too lean
Ran my teg through a computer and it gave me back a code of my fuel mixture too lean according to my o2 sensor. So i replaced the sensor and my fuel mix is still too lean. My engine isnt getting enough gas, and im not getting enuff speed. Also, when I brake fast my car shuts off. Could it be a problem with vaccuum hoses, fuel pump, fuel filter? I ordered new cold air intake, so maybe that can help out. I need suggestions. Thanks H-T'ers
Old Sep 21, 2004 | 09:13 AM
RallyRedGT-V6's Avatar
Default Re: Fuel Mix too lean (Mike1486)
ok..too lean means too much air for the fuel thats getting dumped in..why did you get something that restricts airflow even less? its just gonna get leaner
Old Sep 21, 2004 | 09:30 AM
evil_schmevil
Guest
Posts: n/a
try a tank of Chevron gas with Techron or their injector cleaner.
Or, pull the injectors and have them ultrasonically cleaned
or get an adjustable fuel pressure regulator and crank up the pressure.
Sounds like maybe a vacuum leak. The power brakes use vacuum to assist the braking system. Check the lines going from the brake booster to the manifold.
Old Sep 21, 2004 | 09:44 AM
Mike1486's Avatar
Default Re: Fuel Mix too lean (96integra)
if i got something that restricts airflow and my fuel mix is lean... wouldnt that be a good thing? less air means less air mixing with the all ready too MUCH air with my gas. imma try changing hoses, filters and cleaning injectors.
Old Sep 21, 2004 | 12:44 PM
dick_213's Avatar
in other words.... dont hook up the CAI until the problem is solved...
jakem200
Apr 29, 2009 06:03 PM
DAtegLs
Mar 18, 2009 06:13 AM
JDM_SOHC
Nov 7, 2008 06:05 PM
Mike1486
Sep 22, 2004 12:30 PM
IwanAturBo
Mar 16, 2003 06:53 PM
