Hydro lock with short ram intake??
I know that with a cold air intake I can get a bypass valve to avoid getting water in my engine, but would a short ram system eliminate this threat also? Would it perform as well as a cold air intake? Thanks.
Oh, get a K&N filter too right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lostcb7 »</TD></TR><TR><TD CLASS="quote">If you hydrolock your engine with a short ram, I think hydrolock is actually the least of your problems. </TD></TR></TABLE>
what are you trying to say? do you even know what's hydrolock is?
you pretty much cannot suck in water with a shortram unless you trying to cross the altantic ocean with your accord.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">what are you trying to say? do you even know what's hydrolock is?
you pretty much cannot suck in water with a shortram unless you trying to cross the altantic ocean with your accord.</TD></TR></TABLE>
Of course I know what hydrolock is. Perhaps I didn't word my response well. Gimme_h22 was originally asking if he needed a bypass valve for his short ram intake. What I was attempting to say was that if you hydrolock your car with a SRI then the hydrolocked engine is the least of your problems becuase the water is probably on the inside of the car. With water that high up, I'd be more worried about getting out alive rather than my engine hydrolocking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gimme_h22 »</TD></TR><TR><TD CLASS="quote">is there a difference in performance in the short ram and cold air intakes?</TD></TR></TABLE>
theoretically yes, but in reality no.....
both will net you an unnoticable amount of power gain...short ram may increase throttle response, but im not 100% sure of it
Ive noticed better throttle response with my Short Ram, Engine Heat normally isn't a problem because my filter sits behind the Battery, and it never seemed to get warm at all. I change my CAI to short Ram during the Rainy season.
