Oil light after engine start
What is the maximum time to switch the oil light off after engine is started? In my ITR, it lights for about 0.5 to 1 second after starting for the first time, isn't it too much? I switched from 5w50 sytnthetic oil to 10w40 semi and the time period seems longer now. If I start the car for a second time, it switches off immediatelly.
When does your oil light switch off?
I'm using 5w/40 fully synthetic oil and my light takes approx 1 second to go out, possibly even a little longer, but its always doen that in all hondas i have owned so i think its normal enough
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">all cars after an oil change do that.</TD></TR></TABLE>
But my ITR does that after each cold start...
Odd. You might want to hook up an oil pressure gauge to see whats going on in there. I never had a car still that long enough for the oil pressure light to come on when first started.
Even a cheap simple/ temporary one so you can get an idea...
Mine does that as well after cold starts. Usually a second or two. First time I noticed it took that long, I nearly had a heart attack, but the oil light turned off right then.
I'm running 5w30 Mobil 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 »</TD></TR><TR><TD CLASS="quote">could mean that ur rod bearings are going out, thats what creates oil pressure. is there any knocking ?</TD></TR></TABLE>
No knocking at all, the engine runs like new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 »</TD></TR><TR><TD CLASS="quote">could mean that ur rod bearings are going out, thats what creates oil pressure</TD></TR></TABLE>
Please stop.
Please stop.
WTH?
WTH?
Hmm, I wonder what the oil pump does?
sorry, wrong answer!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls »</TD></TR><TR><TD CLASS="quote">
Hmm, I wonder what the oil pump does? </TD></TR></TABLE>
It supplies spark to the plugs
LOL, OWNED.
LOL, OWNED.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY 01-0972 »</TD></TR><TR><TD CLASS="quote">is there any reason to use oil other than 5w 30 for daily non race use? any benifits?</TD></TR></TABLE>
Oh **** :fire: :burn:
*runs away screaming*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CtRdAvESI »</TD></TR><TR><TD CLASS="quote">what weight oil should i use in my r for everyday in and outta vtek im using 5-30 m1 synthetic now </TD></TR></TABLE>
Oh my god make it stop!!!
Oh **** **** we're all dead get the **** out!!!
Wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
*thud*
*ow*
*thud*
*ow*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY 01-0972 »</TD></TR><TR><TD CLASS="quote">is there any reason to use oil other than 5w 30 for daily non race use? any benifits?</TD></TR></TABLE>The weight oil depends on a number of factors. The major ones I can recall from when I spoke to my engine builder were:
1) Bearing clearances
2) Climate that one lives in. Temperature that is.
But ya. I usually use 10w30 myself as it never gets to freezing temperature where I live, but I had several gallons of 5w30 left so I decided to run that for now.
