96 civic hatch... wats good shift point?!?!?
Old Sep 20, 2004 | 09:13 PM
Honda_hatch 96's Avatar
Default 96 civic hatch... wats good shift point?!?!?
SUp.. guys.. i got a 96 civic hatch.. with a stock motor for now... non-v-tec.. yea i no slow... lol but i got an auto meter tac and i wanna no wat is perfect shift point... wat RMP should i set it 2 light up.. cuz i have 2 buy the chip for it.. thanx alot.. also if u got any websites that sell them.. i belive they are called "pills" lil yellow chip that clips on it thanx!
Old Sep 20, 2004 | 09:20 PM
EK k kay's Avatar
Default Re: 96 civic hatch... wats good shift point?!?!? (Honda_hatch 96)
Umm for normal driving I usually shift at 3k. If I wanna smash (not sure if it's even called smashing on this motor) I shift when the needle hits 6k.
Old Sep 20, 2004 | 10:32 PM
94HatchbackSI's Avatar
3.5k to 4 is good. If you want to "dump" on somebody then anything between six and seven is ideal, whatch the first and second gear, they're trickly with SOHC. The third gear is what I call the "lag" gear. You should double cluctch that while "dumping" on somebody.
Old Sep 20, 2004 | 10:37 PM
DelSolSi93's Avatar
Default Re: 96 civic hatch... wats good shift point?!?!? (94HatchbackSI)
I have a Z6 and I usually shift like 3300 normal driving and dump around 6k on someone its probably close to that on a D15 too
Old Sep 20, 2004 | 10:49 PM
Mischiefek
Guest
Posts: n/a
96 hatch redlines at 6800, but you can shift at 7k no prob..
Old Sep 20, 2004 | 10:57 PM
DelSolSi93's Avatar
Default Re: (Mischiefek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mischiefek &raquo;</TD></TR><TR><TD CLASS="quote">96 hatch redlines at 6800, but you can shift at 7k no prob..</TD></TR></TABLE>
No reason to really go above 6k tho in a stock D15 is there? Not even any vtec up there, you're just pounding the motor
Old Sep 20, 2004 | 11:05 PM
EK k kay's Avatar
doesn't the y7 stop making power after 6200rpm?
Old Sep 20, 2004 | 11:32 PM
Default Re: (mrspeaker)
I've gotten mine to seven but it may not have been a good idea. And yes, it does stop making power in the sixes now that you mention it, matter of fact anything past 5.5 is pretty much just your engine asking to go to another gear. Brain fart, my bad.
Old Sep 21, 2004 | 12:00 AM
8o8da9speed's Avatar
Default Re: (94HatchbackSI)
floating some valves, hehe
Old Sep 23, 2004 | 12:31 PM
Mischiefek
Guest
Posts: n/a
Default Re: (DelSolSi93)
true. the y7 stops making power after 6k. but why shift early??? the y7 doesn't make any power around 3k either and thats where its gonna land when you shift early around 6k, so whats your point????
Old Sep 23, 2004 | 12:37 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94HatchbackSI &raquo;</TD></TR><TR><TD CLASS="quote">3.5k to 4 is good. If you want to "dump" on somebody then anything between six and seven is ideal, whatch the first and second gear, they're trickly with SOHC. The third gear is what I call the "lag" gear. You should double cluctch that while "dumping" on somebody. </TD></TR></TABLE>
You should lay off the crack for a while, it's bad for you.
Old Sep 23, 2004 | 01:03 PM
Archidictus's Avatar
Unceasing Measure
Set your shift point to 10,000rpm. The more you rev it the more power you'll get out of it .
Old Sep 23, 2004 | 01:11 PM
nonsense's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Set your shift point to 10,000rpm. The more you rev it the more power you'll get out of it .</TD></TR></TABLE>
I like to turn mine up to 11
Old Sep 23, 2004 | 01:51 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (nonsense)
I shift at 3500, then if I'm listening to the 2 fast 2 furious soundtrack, I redline even if there's traffic muwahahah
Old Sep 23, 2004 | 02:33 PM
CivicEX96's Avatar
LOL
the thread creator's signature is even more funny...
Old Sep 23, 2004 | 02:38 PM
EK22snatch
Guest
Posts: n/a
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">I shift at 3500, then if I'm listening to the 2 fast 2 furious soundtrack, I redline even if there's traffic muwahahah </TD></TR></TABLE>
lmfao! sorry but thats just a good one!
seriously though, dont go past 6k. you really should be shifting around 3k in daily driving anyways since optimal fuel efficiency/distance or w/e is around 2500rpms.
besides, the y7 has no power anyways, so why rev it and hurt it?!
Old Sep 23, 2004 | 02:47 PM
robbieshonda's Avatar
Default Re: (EK22snatch)
6200 after that nooo powa at all..put some **** on it and youll make better powa at 3000. my 3rd gear rocks... turbo your ******
Old Sep 23, 2004 | 03:04 PM
McNizzle's Avatar
lol....why did u change your icon? the old one was awesome
Old Sep 24, 2004 | 08:04 AM
Unceasing Measure
Default Re: (Chris M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M &raquo;</TD></TR><TR><TD CLASS="quote">lol....why did u change your icon? the old one was awesome</TD></TR></TABLE>
I might change it back...just for you =p.
Old Sep 24, 2004 | 08:11 AM
Grimm's Avatar
wow this thread is funny and full of alot of crap...
normal driving = 4500
fuel efficent = 3000
driving hard = 6500
Old Sep 24, 2004 | 08:25 AM
ecahatch's Avatar
Senor Miembro
your car already came with a clock...what's the reason for putting the ones that goes on the walls in your car
Old Sep 24, 2004 | 08:28 AM
Unceasing Measure
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">wow this thread is funny and full of alot of crap...
driving hard = 6500</TD></TR></TABLE>
Normal driving you shift at 4500rpm? LOL! That's way too much time in each gear. I have a d16z6 93 Si, I shift at 2500 "normally", 2100 "efficient" and around 6200 driving hard in a straight line. On a road course, I'll wind that bitch out and keep her hovering at 6400 for ten minutes if I can keep my speed through the corners.
I'm assuming, though, that the originator of the post is a ricer and wants to know how high he can wind his motor without ******* **** up, and on that note I would suggest no higher than 6600rpm because you're making more noise than power above that threshold. Regardless, you'll probably misshift and **** something up, so do whatever you want .
Old Sep 24, 2004 | 08:36 AM
Grimm's Avatar
Normal driving you shift at 4500rpm? LOL! That's way too much time in each gear.</TD></TR></TABLE>
hahaha he said it's way too much time in each gear...
yea you gotta be kidding me?
on the b18c1 I shift at 4500ish,normal driving, and when I had the d16y8 I did the same for normal driving.
2100? where do you land when you change gears?
Old Sep 24, 2004 | 08:39 AM
Unceasing Measure
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">hahaha he said it's way too much time in each gear...
2100? where do you land when you change gears? </TD></TR></TABLE>
Usually between 1500 and 1700. I don't have an interior or any accessories, so my car doesn't require much motivation to keep her moving .
Old Sep 24, 2004 | 09:36 AM
Grimm's Avatar
not much torque down there , least not enough for my likings...
