91 Honda Prelude looking for proformance is turbo a good idea?
Old Sep 20, 2004 | 04:00 PM
oppenheimer's Avatar
Default 91 Honda Prelude looking for proformance is turbo a good idea?
I recently purchased a 91 prelude, and i really need to rebuild the motor (186000 miles) I know it should go for more but it has been run ragged. anyway I want to turbo charge, do they make a kit, if so what company, if not what else can I do?
Old Sep 21, 2004 | 06:27 AM
jdm236's Avatar
Default Re: 91 Honda Prelude looking for proformance is turbo a good idea? (oppenheimer)
ludespeed had a kit but for all the money it would cost to rebuild the motor, swap in a h22a=200hp, add and intake,exhaust,cams and some other stuff and you will be alot happier
Old Sep 21, 2004 | 06:48 AM
eLUDEnu
Guest
Posts: n/a
Default Re: 91 Honda Prelude looking for proformance is turbo a good idea? (jdm236)
First of all the h22 dosent make 200 whp. second of all is it worth rebuilding the motor of such an old car? you can do whatever you want to whatever want but It all comes down to how much money you have
Old Sep 21, 2004 | 07:25 AM
jdm236's Avatar
Default Re: 91 Honda Prelude looking for proformance is turbo a good idea? (eLUDEnu)
my bad i meant 200 hp at the fly wheel but with simple bolt ons it makes up for it, but overall its better than the stoch engine
Old Sep 21, 2004 | 07:52 AM
Power2weight's Avatar
A H22 is a difficult and expensive swap.
Get a JDM B20, they arent expensive at all, then turbo it, should be a good 200whp and much cheaper than H22.
Old Sep 21, 2004 | 07:12 PM
Default Re: 91 Honda Prelude looking for proformance is turbo a good idea? (Power2weight)
I asppreciate the information
Old Sep 21, 2004 | 07:16 PM
red92si's Avatar
Or you can do a B16 headswap
Old Sep 21, 2004 | 08:34 PM
Not_Rice4ws's Avatar
go to preludepower.com and check the for sale section. buy the engine that is already built for boost. then get a custom manifold produced (no one makes a mass produced manifold for the b20a5-b20a motor). then collect the bits for the kit here and there. then get a standalone like hondata or the do it yourself standalone uberdata. then put it all together and run 25psi on the street and eat tires and mustangs.
or you could get forged parts for your motor and the have your block resleeved.
Old Sep 22, 2004 | 02:55 PM
Default 91 lude
could I do a B18 headswap if so do I need a b18 manifold for turbo
Modified by oppenheimer at 8:31 PM 9/22/2004
Old Sep 22, 2004 | 11:31 PM
you do not want to go there.
there is too much moding that needs to be done for the other b series heads to fit on the b20a5 (prelude) block.
just get a custom manifold made by mario and go from there.
Prelude91beginner
Nov 10, 2007 08:24 PM
dadeboy1
Aug 19, 2007 07:55 AM
97me03gst
Aug 1, 2004 05:44 PM
TrboH22
Jul 27, 2002 03:03 PM
