DelSol DualCore Slim Fan--Where to buy?
i got a auotozone dualcore rad and i want to get a slim fan to make sure i stay cool...
i searched and...
https://honda-tech.com/zerothread?id=936861
that seems to be the bandwagon slim everyone is buying.... these the best buy/rightone for the job?
thx
i searched and...
thx
they also sell the slim line fans there though they don't flow very well. Viren B18bturbo I believe is his name sells them cheap and they flow hella good.
Here is the link- https://honda-tech.com/zerothread?id=936861
lol thanks for the reply forsfed but rofl our links are the same
so these are the ones to buy if your on a budget?
what is 1400cfm vs oem stock; anyone know those numbers?
O loo my bad man, the factory ones flow around 600-750cfm's so the 1400 will be the best you will find. Even the fal or spal fans don't flow that much with the same specs and dimensions.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">O loo my bad man, the factory ones flow around 600-750cfm's so the 1400 will be the best you will find. Even the fal or spal fans don't flow that much with the same specs and dimensions.</TD></TR></TABLE>
fal may not flow as much but its a sealed chamber around the radiator. The fan sits off the radiator about 2 inches and the mounts pull the ruber seals tight so the fan cools the entire radiator not just a section of it. The fal fan has the best fit and finish so I bought that one
drift2004
Oct 4, 2004 06:45 PM
