Brakes squeaking? Time to change pads; How do I change them?
Old Dec 10, 2001 | 04:28 PM
onyx00's Avatar
Default Brakes squeaking? Time to change pads; How do I change them?
My brakes are beginning ot squeak so I think my pads need ot be changed. They've seen 10000 miles and three track events. I have some Hawk HP Plus pads to put on, but my question is how do I do it?
Old Dec 10, 2001 | 04:30 PM
chad's Avatar
Moderator
Default Re: Brakes squeaking? Time to change pads; How do I change them? (onyx00)
time to get a helms manuel...just follow the instructions!!!! if you have done 3 track events without bleeding your brakes you are just asking for brake failure!!
Old Dec 10, 2001 | 04:39 PM
onyx00's Avatar
Default Re: Brakes squeaking? Time to change pads; How do I change them? (chad)
Brake system was flushed twice. Did it this summer and again last week. Pedal fels good. I used ATE TYPE 200.
Got the Helms in front of me now
Old Dec 10, 2001 | 04:41 PM
Back in Black's Avatar
Rather OG
Only flushed twice? WOW...
Garth- who bled 4 times this weekend at VIR
Old Dec 10, 2001 | 04:46 PM
EG8R's Avatar
Default Re: Brakes squeaking? Time to change pads; How do I change them? (Darth VadeR)
Flushed and bled are 2 different things....
Old Dec 10, 2001 | 07:40 PM
nsxtcjr's Avatar
New User
You can check the thickness of the braking material at the top of the outer pad by looking through the spokes of the wheel (see detailed instructions in the NSX FAQ link below). If it's about 2 mm thick or less, change them. (It's possible for it to be thicker than 2 mm here but still thinner on the inside pad, so if you want to be thorough, you need to remove the wheels and check the entire pad on each side of the rotor.)
Same way as on the NSX. A how-to for checking and changing brake pads is in the NSX FAQ at http://www.nsxprime.com/FAQ/DIY/brakepads.htm
Old Dec 10, 2001 | 07:45 PM
redteg1's Avatar
Default Re: Brakes squeaking? Time to change pads; How do I change them? (nsxtcjr)
haha me and bom put in my pep boys raybestos after my rear right pad grinded up my rotor and took us a hefty 4hrs! 1st time experimental on the rears so we went back and forth thinking we needed a C clamp...turns out u just turn cross. didn't bleed the brakes...lost a lil fluid and loss of brake pressure for about 2 weeks left me pumping my brakes to get regular pressure back again. be careful driving if that ever happens to u...make sure u keep ur distance. good luck
davemem
Honda CR-V & Element
Dec 12, 2010 07:44 AM
Drive 4 fun
42
Aug 29, 2010 07:35 PM
redDAinteg
Dec 17, 2008 12:18 PM
onyx00
Nov 20, 2001 05:51 PM
onyx00
Jul 3, 2001 09:31 AM
