Need vacuum lines chart of a d16z6 short block into a ef
Old Sep 20, 2004 | 11:11 AM
z6_EF_obd1's Avatar
Default Need vacuum lines chart of a d16z6 short block into a ef
I took my 95 ex's z6 and put it in my 91 std hatch, however it does not feel nearly as strong as it did in my eg coupe. Any info would help
Old Sep 20, 2004 | 11:23 AM
dr_latino999's Avatar
Default Re: Need vacuum lines chart of a d16z6 short block into a ef (z6_EF_obd1)
How is it wired? I.E. OBD-0, or 1?
Old Sep 20, 2004 | 11:26 AM
z6_EF_obd1's Avatar
Default Re: Need vacuum lines chart of a d16z6 short block into a ef (dr_latino999)
obd1, i got a 0-1 converter so everything is obd1 do you know where to find a chart??????
Old Sep 20, 2004 | 11:45 AM
Well, I don't have a chart, but shouldn't you have one on the underside of the eg's hood? I'll go looking through my manuals to see what I can pull up. What symptons other than it doesn't feel as powerful do you have?
Old Sep 20, 2004 | 11:53 AM
z6_EF_obd1's Avatar
well...
-everytime i shift, my tranny holds back a lil before going into gear=new clutch??
-i got a 43 ecu code fuel supply=new fuel filter
-if my car is at a light and my steering wheel is turned all the way to the left, my engine revs but the car doesn't move, my outter right cv boot was bursted so i changed the whole axle but the problem is still there.
any ideas?
Old Sep 20, 2004 | 11:58 AM
hatchback_al's Avatar
what tranny are you using, if you are using the STD tranny on it thats why its so slow, those trannys are horrible
Old Sep 20, 2004 | 12:03 PM
z6_EF_obd1's Avatar
Default Re: Need vacuum lines chart of a d16z6 short block into a ef (hatchback_al)
im using a 91 crx si tranny with a new stock clutch kit from o'reillys. I think the mecanic that installed the clutch didnt know how to work on a cable tranny
Old Sep 21, 2004 | 09:32 AM
z6_EF_obd1's Avatar
well... does anybody know how to fix my lines????????
Old Sep 21, 2004 | 09:36 AM
4drEF's Avatar
Keyboard Humorist
I figure vacuum is vacuum.
You can't really mess them up.
If they are all plugged in, no codes, no idle problems... then it should be good.
Old Sep 22, 2004 | 10:58 AM
Default Re: Need vacuum lines chart of a d16z6 short block into a ef (4drEF)
Try just routing vacuum lines to the closest vacuum nipples, compare your old intake manifolds and try to figure it out, thats the best I can do. I just guessed when I did my y8 swap and my motor runs awesome.
mattv
Sep 18, 2008 09:21 AM
foz
Mar 4, 2004 08:53 AM
fsck3r
10
Dec 23, 2002 03:58 PM
