JDM B16A1 VTEC Solenoid Gasket
Old Sep 20, 2004 | 01:14 AM
alexdog69's Avatar
Default JDM B16A1 VTEC Solenoid Gasket
Has anyone been able to find a USDM equivalent?
I have searched and no one seemed to has found any solution for a leaking vtec solenoid gasket on a jdm b16a1... short of replacing the gasket AND solenoid with one from a USDM B-series VTEC together
Old Sep 20, 2004 | 11:32 AM
alexdog69's Avatar
Default Re: JDM B16A1 VTEC Solenoid Gasket (alexdog69)
bump...
Old Sep 20, 2004 | 11:46 AM
Rywire's Avatar
I would think a 94 del sol dohc vtec would be the part?
Old Sep 20, 2004 | 12:21 PM
spaceman's Avatar
http://www.inlinefour.com they have them
Old Sep 21, 2004 | 06:11 PM
alexdog69's Avatar
Default Re: JDM B16A1 VTEC Solenoid Gasket (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">http://www.inlinefour.com they have them </TD></TR></TABLE>
I bought my first one from them. It's wrong.
I bought a 92-93 GSR one from the dealer as well. It's also wrong.
If you search, other people claim that they tried the 92-93 GSR / 99-00 Si / Del Sol.. and none of them work. I'm not quite sure what the story is.. and if the OBD-0 JDM solenoid is just different.
Someone is telling me P/N 15825-P08-005 works correctly. I have yet to find out what this part is from and have yet to try it.
Old Sep 21, 2004 | 07:05 PM
fourthgenhatchB17's Avatar
Thats strange. Thereare actually 2 gaskets. One between the solenoid/psi unit to head, and one from just the solenoid to the unit. Im guessing your are referring to the one from the unit-to-head?
Old Sep 22, 2004 | 01:39 PM
alexdog69's Avatar
Default Re: JDM B16A1 VTEC Solenoid Gasket (fourthgenhatchB17)
Yes the one between the unit and the side of the head. It has the mesh filter in it.
Old Sep 22, 2004 | 05:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 &raquo;</TD></TR><TR><TD CLASS="quote">Yes the one between the unit and the side of the head. It has the mesh filter in it.</TD></TR></TABLE>
I dont know why a 94-97 B16 del sol or a 99-00 Si gasket doesnt fit perfect. It should. Can someone psot pics of this difference, cuz i dont see how it could be.
Edit: that part number u listed with PO8 in it, isnt that a JDM SOHC VTEC p/n? Dont the JDM sohc vtec's use a PO8 ECU? I just connected the 2 but maybe im wrong.
Old Sep 26, 2004 | 06:52 PM
alexdog69's Avatar
i have 2 torn gaskets sitting in my garage .. i dont have any pics of this shameful sight tho
hmm..
https://honda-tech.com/zerothread?id=238924
i wonder why no one has figured this out .. ive searched plenty .. people end up getting so pissed they change the soelnoid.... maybe the gasket really is a jdm only part or something..
Old Oct 9, 2004 | 01:34 PM
alexdog69's Avatar
I've found the right gasket. 91 NSX. 15825-PR3-005
Old Oct 9, 2004 | 01:42 PM
type Gendy's Avatar
I'm pretty sure when i replaced mine i used a b16a3 gasket from honda. I have a receipt here...it just says filter, s.. but i think its for the vtec solenoid.
Part numbers: 15825-p08-005 and 36172-p08-005. No leaks since
Old Oct 9, 2004 | 01:46 PM
Bserieskllr's Avatar
what about the integra type r one, they do have the same heads.
Old Oct 9, 2004 | 02:37 PM
Redline130's Avatar
Default Re: (Bserieskllr)
I've always used a Del Sol VTEC one, no troubles with it.
Old Oct 9, 2004 | 04:26 PM
HamiltonRex's Avatar
Default Re: (Redline130)
gasket sealer
anyone have pic's of the USDM vs the JDM vtec solenoids?
Old Oct 9, 2004 | 04:48 PM
type Gendy's Avatar
Default Re: (HamiltonRex)
From what i remember... I dont think there is a difference...? at least not between a b16a or b16a3
Old Oct 9, 2004 | 06:54 PM
michael O's Avatar
Default Re: (Evil Sick hatcheM)
I've never seen a b16a1. Where exactly does it come from? Europe?
Old Oct 10, 2004 | 06:27 AM
blah13's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen a b16a1. Where exactly does it come from? Europe?</TD></TR></TABLE>
Its just an obd-0 b16, most people know there are no numbers on jmd b16's but its easier to call it a1 a2 a3 for referencing obd.
Old Oct 10, 2004 | 06:52 AM
ProjectCRXtacy's Avatar
Default Re: (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Its just an obd-0 b16, most people know there are no numbers on jmd b16's but its easier to call it a1 a2 a3 for referencing obd.</TD></TR></TABLE>
Umm, the JDM B16a is not a1. If I rememer correctly, B16a1 is a USDM B16.....as well as B16a2, etc. B16a signifies JDM obd0 B16.
edit: I just reread what you typed, my bad, you're right. It's still incorrect to call the JDM b16a a b16a1 though.
Old Oct 10, 2004 | 12:35 PM
alexdog69's Avatar
The JDM B16A/PR3 EF SiR solenoid is dfiferent. I can't comment on the XSi B16A, however.
P08 is not the right gasket.
15825-P08-005 compatible solenoid:
Left to right: EF B16A/PR3 solenoid, 15825-PR3-005, 15825-P08-005
Notice the PR3 has a sharp bend at the top and the P08 has a smooth curve. The P08 is also much thicker.
If you look at the different DOHC solenoids (PR3 vs P08 style) you will see the differences in the gaskets CLEARLY reflected in the machining of the solenoid face.
The areas circled in red will usually tear when you put a P08 gasket in a PR3 solenoid.
I tried the P08. Twice. It was wrong. It could have worked if I rednecked it a bit more. It was a sloppy install at best.
I did a lot of searches. Other people had the same problem. They tried every USDM equivalent they could think of.
YMMV
For me, the 91 NSX (15825-PR3-005) gasket was the correct part.
Old Oct 10, 2004 | 03:54 PM
Default Re: (alexdog69)
gasket maker!
Old Oct 11, 2004 | 10:37 AM
So people with first gen B16's and want a new VTEC solenoid gasket should get one from a 91 NSX correct?
Nice detailed pics too.
Old Oct 11, 2004 | 10:40 AM
michael O's Avatar
Good to know. I too was confused when I ordered the gasket for the del sol, installed it, and then had a huge puddle of oil under my car upon startup.
Old Oct 11, 2004 | 03:13 PM
alexdog69's Avatar
Yes.. 91 NSX.. 15825-PR3-005
Thanks for the
Old Oct 11, 2004 | 05:32 PM
HonduHHerB's Avatar
thanks here also , just relized That I needed same gasket and parts stores thoght I was crazy!
Old Oct 12, 2004 | 12:41 PM
gringo7718's Avatar
Default Re: (HonduHHerB)
YES YES i fukd up 3 of them from 99-00si and i thought it was my fault. i ended up just rvt siliconing it in...which worked, but Thank You.
broken 99 si vtec solenoid
Modified by gringo7718 at 9:57 PM 10/12/2004
