Exedy Racing Lightweight Flywheels in stock from $255.60!
Exedy Racing flywheels are made from solid one-piece billet chrome moly steel or chorome moly steel forgings. They are specifically designed to reduce weight and intertia for better engine response. Most models incorporate special design features to enhance the airflow and improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibilities of separating from the flywheel and exploding. This is caused by two different expansion coefficients (aluminum flywheel pressed on steel ring gear). Exedy steel billet and forged steel flywheels have passed engineering tests of up to 15,000 rpm. And is guaranteed to be explosion proof at the said rpm.
Order your Exedy Flywheel here
Acura Integra 1992 - 1993 HF01 $255.60 Trim: 1.7L Specs: Billet Steel Flywheel
Acura Integra 1990 - 2001 HF01 $255.60 Trim: 1.8L Specs: Billet Steel Flywheel
Acura RSX 2002 - Up HF02 $378.00 Trim: 2.0L Specs: Billet Steel Flywheel
Ford Mustang EF06 $97.74 Trim: 6 Bolt Specs: Billet Flywheel
Ford Mustang EF08 $97.74 Trim: 8 Bolt Specs: Billet Flywheel
Honda Civic 1999 - 2000 HF01 $255.60 Trim: SI 1.6L Specs: Billet Steel Flywheel
Honda Civic 2002 - Up HF02 $378.00 Trim: Si 2.0L Specs: Billet Steel Flywheel
Honda Civic 1990 - 1993 HF04 $378.00 Specs: Billet Steel Flywheel
Honda Civic 1990 - 2003 HF501 $255.60 Trim: SOHC Specs: Billet Steel Flywheel
Honda Del Sol 1994 - 1997 HF01 $255.60 Trim: 1.6L Specs: Billet Steel Flywheel
Honda Prelude 1992 - 2002 HF03 $378.00 Trim: Specs: Billet Steel Flywheel
Mazda 3 2004 - Up ZF501 $341.10 Trim: 2.0/2.3L Specs: DOHC Billet Steel Flywheel
Mazda 6 2003 - Up ZF502 $341.10 Trim: 2.3L Specs: DOHC Billet Steel Flywheel
Mazda 6 2003 - Up ZF503 $341.10 Trim: 3.0L Specs: DOHC V6 Billet Steel Flywheel
Mazda RX7 1986 - 1996 ZF01 $401.63 Trim: 13BT - requires flywheel adapter N351 11 521 Specs: DOHC Billet Steel Flywheel
Mitsubishi Eclipse 1989 - 1999 MF01 $429.98 Trim: AWD 7 BOLT Specs: Billet Steel Flywheel
Mitsubishi Eclipse 1991 - 1994 MF03 $429.98 Trim: AWD 6 BOLT Specs: Billet Steel Flywheel
Nissan 240SX 1991 - 1996 NF02 $429.98 Trim: SR20DET / Sylvia 2.0L Specs: Billet Steel Flywheel
Nissan S15 NF03 $429.98 Trim: Silvia Specs: Billet Steel Flywheel
Nissan Skyline NF01 $429.98 Specs: Billet Steel Flywheel
Subaru Impreza 2002 - 2004 FF01 $411.08 Trim: 2.0 / 2.2L Turbo Specs: Billet Flywheel
Subaru Impreza 1999 - 2000 FF02 $411.08 Trim: 2.5L Specs: Billet Flywheel
Subaru WRX 2002 - 2004 FF01 $411.08 Trim: 2.0L Turbo Specs: Billet Flywheel
Toyota MR2 1986 - 1989 TF01 $311.53 Trim: 1.6L Specs: Billet Steel Flywheel
