buring to much gas.. HELP
Old Dec 10, 2001 | 01:14 PM
pg_thao's Avatar
Default buring to much gas.. HELP
i've recently swap a 91 ls motor into a ef, its has header, intake, exhaust, fuel gauge and regulator, the problem is that it seems to leak or burn alot of gas, i've lean out the car and it still wastes alot of gas, usaully 4-6 miles per gallon.. i've also check the gas lines, fuel pump, spark plugs, plug wires,.. i need help...
also it throwing a code 7 for the tps sensor and code 13 for pa sensor
Old Dec 10, 2001 | 02:20 PM
Spade's Avatar
Default Re: buring to much gas.. HELP (pg_thao)
check the o2 sensors, and you might have some dirty fuel injectors.
aystupet
Jun 17, 2010 08:41 PM
Ferio4ya
Nov 30, 2009 01:17 PM
00s2KkId
Oct 27, 2004 02:32 PM
acuracing
Jun 1, 2003 08:31 PM
