why do I have water in my floor board????????
Old Sep 19, 2004 | 07:38 PM
thehondaguru's Avatar
Default why do I have water in my floor board????????
Ok I FINALLY got some internet back since frances hit us... dont ask!!!
When the huricane was finally gone and had a chance to drive the prelude I noticed a considerable amount of water on my passenger side floor.
Now here is the kicker there is no leak in the roof, moonroof, or the windsheild. When it rains it gets wet only on the passenger floor. No where else not on the seat or anyother part higher than the floor. THE FLOOR ONLY. How the hell does this happen????
Old Sep 19, 2004 | 07:39 PM
Default Re: why do I have water in my floor board???????? (95 lude)
whoops sorry!!!
Old Sep 19, 2004 | 07:50 PM
Nikoli's Avatar
maybe water is running down your door and the weather stripping isnt sealing
btw...thanks for that lip sorry i didnt hang out more. it was a pretty hectic day and i fucked my foot up so i was limpin around
Old Sep 19, 2004 | 07:57 PM
Default Re: why do I have water in my floor board???????? (Deckedlude)
maybe but the seal is in good shape. It doesnt show any signs of a leak anywhere at all. I never see any leaks while driving it but as soon as I stop and let it sit it starts accumulation water some how.
No problem about the lip. I was gonna just throw it away anyway. Nopi was alright a little too much rice for my taste though. (The professional show cars dont count in that I mean the ones people like you and I could enter)
Either way it was fun
Old Sep 19, 2004 | 08:59 PM
revlimitx04's Avatar
an exgirlfriend of mine had a 01 Lancer, it had excessive water in the floor board.. it was the AC drainage system plugged up on the condinsation tube. Check for the AC condensation runoff stem somewhere on the firewall..
Old Sep 19, 2004 | 09:34 PM
skrewdlude's Avatar
This happened to my old lude once. The one of the sunroof drain valves got disconnected...and the drain valve was dumping into the passenger floor board. It is up under the dash. It would make the floor soaked when it rained. The tube is easily pulled out if you are messing around down there. The drain tubes run down the A pillar inside the car, into a little grommet that directs the water out of the passenger compartment, and into the fender area.
-Josh
Old Sep 20, 2004 | 05:36 AM
LudeyKrus's Avatar
there's also a bunch of wires running from outside the fenderwell into the passenger compartment; it is sealed w/ a rubber grommet thing. Look at where the passenger's feet sit; then look to the right, in front of the door jam. Pull back the carpet and you should see what i'm talking about. See if the rubber boot is torn around the wires.
Old Sep 20, 2004 | 06:14 AM
Default Re: (LudeyKrus)
That rubber boot is torn. The one that goes into the fender area right? yeah its torn, but I dont see that being the problem. But it could be I will try to fix that. And seee what happends
Old Sep 20, 2004 | 08:08 AM
DarkBB4's Avatar
Default Re: (95 lude)
yo prolly not good considering the ecu is right under the passenger floorboard..
good luck and bump
Old Sep 20, 2004 | 10:09 AM
Default Re: (DarkspeedVtec95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">yo prolly not good considering the ecu is right under the passenger floorboard..
good luck and bump </TD></TR></TABLE>
ahh screw the ecu ya know
Old Sep 20, 2004 | 05:34 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">That rubber boot is torn. The one that goes into the fender area right? yeah its torn, but I dont see that being the problem. But it could be I will try to fix that. And seee what happends</TD></TR></TABLE>
Well I tore mine by accident, and when I drove it in a storm, it absolutely SOAKED my floorboard! But that was w/ the tires kickin the water up onto it....
Old Sep 21, 2004 | 07:51 AM
that may be it but it never gets wet if I drive the car
biscuit01ex
Honda Civic (2001 - 2005)
Apr 30, 2006 11:20 PM
BadEH2
Mar 24, 2005 09:59 AM
PatrickGSR94
Jan 30, 2005 02:38 PM
hOndafienD 04
Dec 9, 2004 11:13 AM
.Ryan
13
Dec 23, 2002 10:32 AM
