got pics of your clean battery relocation? show me...
Old Sep 19, 2004 | 06:23 PM
elmalouno's Avatar
Default got pics of your clean battery relocation? show me...
i searched and found some stuff but alot of pics no longer working.
i wanna relocate my battery, so give me some ideas? also mention what you used... aka kit from summit ... optima battery... garden hose... ex..
thanks
Old Sep 19, 2004 | 06:40 PM
ScottEK's Avatar
Default Re: got pics of your clean battery relocation? show me... (elmalouno)
Mine is posted in this thread: https://honda-tech.com/zerothread?id=976109
Old Sep 19, 2004 | 07:02 PM
HatchBox's Avatar
Skoobie no more...
Default Re: got pics of your clean battery relocation? show me... (beta13)
4 guage wire from any electronics store, and a battery box, unless you want to buy the summit kit..
Old Sep 19, 2004 | 07:03 PM
RacerBoy's Avatar
Default Re: got pics of your clean battery relocation? show me... (HatchBox)
Whats ur purpose? I had a Odyssey dry cell facing down to clear my intake for the turbo. OR, you can store it in the crx storage behind the seats and run the wires.
Old Sep 19, 2004 | 10:55 PM
Josh.'s Avatar
Ok, so thats how it sat with the battery installed. The lower piece holding the battery was just a 90 degree corner piece of aluminum. It had enought of an edge to hold each side of the battery (side and bottom) snugly. Looked kinda like this:
One hole was drilled on the bottom part of the bracket on each side and the stock battery hold down rods were used to go through the holes (straight ends through the bottom with 2 nuts to hold it in place). The angeled top parts supprisingly fit into 2 holes in the chassie that were already there. This kind of shows the rods / bracket.
For the top piece I just had a sheet of aluminum and cut out a bit, drilled a hole in the piece where there was an existing bolt hole in the chassie and stuck it on to hold the battery down. This pic shows that good.
As you can tell a baker battery was used. I cut some cut some 4 gauge wire to fit the lengths I needed. Used pieces of aluminum I found laying around the garage, check with your parents / wife / roommate to make sure the stuff isnt important before you cut it up and use it.
I would have taken more pictures if I would have known so many people would be interested... let me know if you have any questions about it and I'll answer the best I can. I sold the car awhile back so I cant get anymore pictues for you guys.
Modified by rollinonfifteens at 10:12 AM 9/20/2004
Modified by rollinonfifteens at 10:14 AM 9/20/2004
Modified by rollinonfifteens at 10:19 AM 9/20/2004
Old Sep 19, 2004 | 11:05 PM
JCracer723's Avatar
Default Re: (rollinonfifteens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonfifteens &raquo;</TD></TR><TR><TD CLASS="quote">
Used a baker battery, cut some 4 gauge wire to fit the lengths I needed, made a little bracket, and called it a day.
u got pics of the braket/tray without the batt on ??
Old Sep 19, 2004 | 11:32 PM
608 Gangsta's Avatar
Default Re: (JCracer723)
thats a cool plac for the batery up front there never seen that before **"CUSTOM"**
Old Sep 19, 2004 | 11:39 PM
SiR Inspired ED7's Avatar
good place, good work. how long it take ? 30 min?
Old Sep 20, 2004 | 08:43 AM
NCchris's Avatar
Default Re: (-=*Dusk2Dawn*=-)
I did mine like this: http://crx.honda-perf.org/arti....html
HTH
chris
Old Sep 20, 2004 | 08:46 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">i searched and found some stuff but alot of pics no longer working.
thanks </TD></TR></TABLE>
If you gonna ever run at the track and they are stricted with the rules, I would follow some of the nhra rules.
Battery may be located in a sealed .024 inch steel, .032 inch aluminum or NHRA approved box. Box may not be used to secure battery and must be vented outside. Relocated battery must be fastened to the frame.
Just a little info if your gonna run at the track.
Old Sep 20, 2004 | 09:16 AM
Josh.'s Avatar
edited my previous post with some more info.
Old Sep 20, 2004 | 10:01 AM
dr_latino999's Avatar
My not NHRA apporved battery relocation:
&lt;We-Todd is done for now, sorry. Will get picture up when up&gt;
boosted civic 2k6
Dec 4, 2005 01:30 PM
sl0wED
Sep 3, 2004 10:20 PM
h22turbolude
Dec 18, 2003 07:02 PM
teg92
Dec 26, 2001 09:44 AM
