what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap?
Old Sep 19, 2004 | 05:05 PM
superturboprelude's Avatar
Default what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap?
ok here i am about make a decsision because i am kinda of getting tired of my car i have a prelude 1992 with jdm lsd h22a but i dont know if i should sell the car and get a sc300 then swap it out for a tt supra motor or stay with the lude and swap in for an h22a7 euro r but heres the thing i want a car that will be able to have reliablitly , handling , easy to work on , looks , cheap , and be able to run high 12s or low 12s but just asking for opinion thanks in advance and ive have always like the lude for its comfort handling and decent powere but i wanna hear from you guys thanks
Old Sep 19, 2004 | 05:09 PM
flip1199's Avatar
Default Re: what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap? (superjunprelude)
fast, cheap, reliable.....pick 2
Old Sep 19, 2004 | 05:20 PM
Default Re: what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap? (flip1199)
prelude or sc300?
Old Sep 19, 2004 | 05:50 PM
Daboi630's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">ok here i am about make a decsision because i am kinda of getting tired of my car i have a prelude 1992 with jdm lsd h22a but i dont know if i should sell the car and get a sc300 then swap it out for a tt supra motor or stay with the lude and swap in for an h22a7 euro r but heres the thing i want a car that will be able to have reliablitly , handling , easy to work on , looks , cheap , and be able to run high 12s or low 12s but just asking for opinion thanks in advance and ive have always like the lude for its comfort handling and decent powere but i wanna hear from you guys thanks </TD></TR></TABLE>
reliability
handling
easy to work on
looks
cheap
run 12s
don't ask for too much now.
let's see. first you have a jdm h22 in your car and if you keep it you plan on yankin it out to put in a h22a7?? why not just save all that money and BUILD your h22a?
sc300TT - have you done research on this? talk about NOT being cheap
Old Sep 19, 2004 | 05:53 PM
satan_srv's Avatar
uh I don't think either of the plans on either of those cars is cheap
Old Sep 19, 2004 | 05:54 PM
Kal's Avatar
Kal
not cheap at all haha.
Old Sep 19, 2004 | 05:58 PM
MugenPoweredLude's Avatar
neither are cheap
but I would say sc300TT
the power you can make on the almight 2jz seems nearly infinite on a stock bottom end
Old Sep 19, 2004 | 06:12 PM
Matgallis's Avatar
Default Re: (MugenPoweredLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude &raquo;</TD></TR><TR><TD CLASS="quote">the power you can make on the almight 2jz seems nearly infinite on a stock bottom end </TD></TR></TABLE>or around a k
Old Sep 19, 2004 | 06:19 PM
bad-monkey's Avatar
i think the SC300 will handle like a boat. it'll be fast in a straight line though.
Old Sep 19, 2004 | 06:57 PM
eLUDEnu
Guest
Posts: n/a
Default Re: (bad-monkey)
HMMMM..... let me ponder on this one.. You are asking the prelude forum.. The damn lude screw toyota
Old Sep 20, 2004 | 10:59 AM
chitownrida's Avatar
like daboy says its not gonna be cheap, think about also the labor involved. .. my main concerns
1.most sc300's are automatic
2. engine wiring
i dont think this is a feasible swap for someone on a budget
Old Sep 24, 2004 | 11:28 PM
fantabulous's Avatar
Default Re: (chitownrida)
if money is not an issue, go for the sc300. and when purchasing your 2jz, try purchasing the non ETCS (electronic throttle control system) blocks (93-95 i believe). 2jz into 240sx project is goin slow. wiring up an etcs ecu is tricky. the ecu is look for a wheel speed sensor input in a car that is non ABS equipped. thinkin about disabling and switching to cable operation to save head aches. what im trying to say is try and pic a motor with the same availible options on the sc300. it'll be a lot easier than putting a 2jz into a nissan tho.
oh yeh, if you live in cali, how do u expect to pass emissions with a 2jz turbo in a sc300?
Old Sep 24, 2004 | 11:31 PM
fastlude69's Avatar
you can just turbo the sc300 for like cheap just throw on a ticket headgasket not worth swaping the motor
Old Sep 24, 2004 | 11:42 PM
@ries's Avatar
Get the SC and sell me your LSD tranny.
Old Sep 24, 2004 | 11:52 PM
Default Re: what do you guys think sc300 with 2jzgte swap or prelude h22 euro swap? (@ries)
turbo'ing the non turbo 2jz that already comes in the sc300 is really a pain. the turbo 2jz swap would be about the same price of a turbo kit and everything else needed to turbo the sc300, but having a lot more potential. with the turbo kit on the sc300, normal outputs are like 310hp stock everything else. might as well just do the swap when you could be 300hp stock. boost controller, cams, exhaust, 400 plus is easy.
Old Sep 25, 2004 | 03:18 AM
nah i have changed my mind and stayed with the lude lol
Old Sep 25, 2004 | 04:24 AM
biggdogg's Avatar
cheap ....ahahahahahahahahahahahahaa! no hobby is cheap unless you collect boogers under your chair . i know i have a fine collection myself . (adding to it right now).
Old Sep 29, 2004 | 08:28 PM
accordm3's Avatar
what kind of moron would you be for swapping a h22a for a euro r h22? buy a euro r manifold for 200$ and buy some skunk2 stage 2's and put down 20 more hp than a damn euro r. sounds like a ricer proposition to me
Entaka
Aug 10, 2005 02:39 AM
OzWolfbane
Feb 12, 2005 08:23 PM
Twilightepitaph
Dec 12, 2004 12:07 AM
joejoefosho
Sep 10, 2003 12:30 AM
jeff652
Sep 9, 2002 05:34 AM
