Catalytic Convertor Power Losses
Old Sep 19, 2004 | 10:50 AM
panykus's Avatar
Default Catalytic Convertor Power Losses
How much Horsepower/Torque losses can you expect from adding a catalytic converter to a straight pipe to pass emmisions testing? I would be adding a 2.5 " high flow cat. Know of any muffler shops in the Seattle Area that would make me a test pipe too? Thanks for your help!
Old Sep 19, 2004 | 11:01 AM
zad5's Avatar
they make some good flowing cats liket he carsound cats it flows almost as good as a str8 pipe. for all motor it doesnt matter much as turbo. there is a dyno with the carsound against a test pipe the test pipe made 1 hp more but the carsound had 1 torque more.
Old Sep 19, 2004 | 11:06 AM
panykus's Avatar
Default Re: (zad5)
thanks zad5 for the info - I forgot to ask if I need and OBD I or OBD II cat caonvertoer. According to the muffler shop I spoke to there's a significant difference in price ($260 installed for OBD I vs $400 installed for OBD II). Using the wrong one will apparantly cause the cat to be blown up or worn out prematurely - can anyone verify if that is correct? My motor is a 95 GSR Head and Block with a stand alone AEM EMS. Thanks!
Old Sep 19, 2004 | 11:13 AM
D1703's Avatar
Default Re: (panykus)
it won't really matter unless you are in CA and have to do smog. OBDII cats just have a better filter that the dyno smog machine will pick up. The only time you would need a OBD II cat is if you car is 96+
Old Sep 19, 2004 | 11:52 AM
eyeamvic's Avatar
There was a dynosheet comparing a straight pipe and a high flow cat. The difference was only a SMALL gain. I would suggest just keeping the high flow cat instead of going with straight pipe. Killing the environment isn't worth the 1-2hp. I still need to install the 2.5" cat and get the custom piping done soon.
Old Sep 19, 2004 | 01:01 PM
zad5's Avatar
Default Re: (D1703)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D1703 &raquo;</TD></TR><TR><TD CLASS="quote">it won't really matter unless you are in CA and have to do smog. OBDII cats just have a better filter that the dyno smog machine will pick up. The only time you would need a OBD II cat is if you car is 96+</TD></TR></TABLE>
it does matter on some applications. some header do not have an o2 bung and so the obd2 cats have a bung before the cat and after the cat. you can always get an obd1 cat and get a bung welded. if you get an obd1 cat make sure it is a three way cat. also the price the guy gave you are ridcilous buy a carsound cat from ebay are you 2.5" if you are get the 94066 should be around 70 dollar or so should be less then 100
Old Sep 19, 2004 | 01:21 PM
SMSP's Avatar
Default Re: (zad5)
Don't buy the 94005, 94006, 94035, 94036, 94065 or 94066 cats.
Old Sep 19, 2004 | 04:19 PM
panykus's Avatar
Default Re: (SMSP)
Thanks everyone for your input - I am a little confused though... For my application (95 GSR Block and Head with AEM EMS stand alone ecu), I should use a OBD I Cat correct? As far as the price to install, the $260 was installation including the price for the muffler. How many hours worth of labor or how much in labor costs should it be to install a cat converter? As far which cat to get, should I get a carsound 94066 (OBD I ?) or a SMSP high flow cat? OBD I or OBD II? Thanks again and sorry for the confusion...
PurpleAccord88
Feb 3, 2007 08:32 PM
aemintgsr
Jan 10, 2005 12:18 PM
PowerHouse
Jul 22, 2004 11:04 PM
GOLDBERG
11
Sep 7, 2003 02:04 PM
jdmrealm
Dec 10, 2001 01:21 PM
