the diff between F22a1 & F22a6
I read that the reason the f22a6 makes an additional 15 hp over a1 is due to the "dual-stage intake manifold" Is that the only difference?(I'm sure there's more but what is it) If not, I want to play mix and match.
But, the a6 only makes 5 pounds more torque. Is it really a faster motor? Anyone compaired the two? (a CB7 LX and EX)
To my knowledge the only other differences were that the a6 had a slightly different camshaft design as well as the exhaust manifold is larger on the a6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lostcb7 »</TD></TR><TR><TD CLASS="quote">To my knowledge the only other differences were that the a6 had a slightly different camshaft design as well as the exhaust manifold is larger on the a6.</TD></TR></TABLE>
its not that its larger, its that it is a 4-2-1 design whereas the f22a1 is a 4-1 design.
couldn;t comment on the camshaft, i dont care enough about the f series to know that about em.
but you can see even more gains with a h23 intake manifold and throttle body and then a a6 exhaust manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaGGed HoNDa »</TD></TR><TR><TD CLASS="quote">the intake manifold is different also</TD></TR></TABLE>
thats already been covered...
livinlow
Welding / Fabrication
20
Dec 15, 2005 12:21 PM
