won't run right
won't run right
88 accordlx 2.0bbl will sometimes run but will die out after a few min of driving. I have replaced the: fuel pump, fuel filter, rebuilt carbuerator, replaced plugs, wires, cap, rotor, ignition module, coil, air filter. Problem will not go away.. Please help!!!
Re: won't run right (88accordlx)
How many miles is on your engine? The engine could be excessively worn and its time for a rebuild. But dont jump to that conclusion yet. You might not be keeping compression. After replacing everything it sounds it could be. If the motor does need to be replaced now would be a good time for a engine swop.
Re: won't run right (DragonTLS)
like i suggest to everyone that has the carb'd models.... have you had all the vacuum lines checked for leaks? i know there's a billion of them in there, but i've seen leaky vacuum lines cause all sorts of problems.
jdm_sir2
03-31-2008 10:05 PM
m1ndless
11-30-2007 11:31 PM
SOHCMAN
11-03-2007 05:42 AM
