HELP!!!.... oil pressure sending unit
Old Sep 18, 2004 | 08:11 PM
fro's Avatar
fro
Default HELP!!!.... oil pressure sending unit
what is the easiest way to take off the oil pressure sending unit without taking off the intake manifold, or do i absoutly have to take it off.
Old Sep 18, 2004 | 08:23 PM
non-VTEC's Avatar
Default Re: HELP!!!.... oil pressure sending unit (fro)
you can get to the sending uning from under the car.....just like your changing the oil filter its sitting right beside it.......you may have to remove the oil filter to give yourself more room to remove it. i do belive its a pretty big socket....22 or 24mm is needed to remove it.
who ever told you you need to take the intake manifold off does not know what they are talking about and you should not take anymore advice from them.
Old Sep 18, 2004 | 09:35 PM
fro's Avatar
fro
where exactley is the oil pressure sending unit? I disconnected a green connection off of what I thought was the sending unit...it was straight up from the filter under the intake manifold...but there is also another connecting up and to the left of the oil filter with a rubber boot on in with wires coming out of it...which one is the sending unit?????
Old Sep 18, 2004 | 09:58 PM
boosted k20's Avatar
the sending unit is the one to the left of the oil filter with the rubber boot on it
Old Sep 18, 2004 | 10:01 PM
fro's Avatar
fro
Default Re: HELP!!!.... oil pressure sending unit (boosted k20)
ok, now how do i disconnect the sensor from it?
Old Sep 18, 2004 | 10:43 PM
Xsi's Avatar
Xsi
You just unplug it at the back I think. Just looking at mine, it seems to be bigger than 24mm and smaller than 27mm, looks like I have to buy a new socket
Old Sep 18, 2004 | 10:52 PM
fro's Avatar
fro
Default Re: (Xsi)
it doesnt want to pull out so what should i do then.
Old Sep 19, 2004 | 05:55 PM
Xsi's Avatar
Xsi
Mine is just a spade terminal so it just pulls outwards.
scvludedood
Apr 27, 2009 08:06 PM
DavidR
Feb 13, 2006 04:03 PM
dseriessol
Feb 29, 2004 03:31 PM
Anderson
Jun 20, 2002 07:45 PM
Acura_I-RS
May 12, 2002 05:20 AM
