who makes cams for the ep3
Old Sep 18, 2004 | 07:37 PM
in-n-outboy's Avatar
Default who makes cams for the ep3
i was wandering who made cams for the ep3 i think skunk 2 makes them but who else
Old Sep 18, 2004 | 09:29 PM
Kal's Avatar
Kal
Default Re: who makes cams for the ep3 (in-n-outboy)
skunk2 is developing them...no one else because the head of the a3 isn't the best for an N/A application when compared to the a2 or a head.
Old Sep 19, 2004 | 08:08 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: who makes cams for the ep3 (Kal)
As Kal said Skunk2 should have some out pretty soon, althought I'm curious to see how high they go (I.e: Stage 1, 2 or 3?). Like I've said before you may want to give them a call, as they usually don't list all their products on the official website.
Old Sep 19, 2004 | 09:49 PM
Default Re: who makes cams for the ep3 (khunt0012)
do u guys think it would be better to get a head swap instead
Old Sep 19, 2004 | 11:12 PM
howl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by in-n-outboy &raquo;</TD></TR><TR><TD CLASS="quote">do u guys think it would be better to get a head swap instead</TD></TR></TABLE>
Yes. Then you can either go with OEM ITR cams or Skunk2 / Toda's.
Old Sep 20, 2004 | 04:38 AM
Mugen Dom's Avatar
Default Re: who makes cams for the ep3 (pr0ns74r)
only thing with the headswap is ur gonna be making power in a different part of the rpm range....and with the si 5 speed not gonna be making use of the power....so what im getting at a headswap is not the most economical way of making u go faster...yes more power is good but if u can use it why bother...and 2 the a3 bottom end just isnt great as most know. So if u want to upgrade the head great but then u have a great head that can rev to 8k but a bottom end that could take a ****.... Probably wont but could....so u may want to just get the cams which will keep ur powerband where u want it....upgrade ur springs and retainers....get the hondata k pro or something to that effect and stick with the 5 speed.....or get the whole typeS motor/6 speed and be done with it then get cams and everything for that...but its ur money so use it wisely plan ahead wish i did a long time ago....starting to do things right the first time makes it alot less stressful in the end even if it takes longer you'll be happier with the results
Old Sep 20, 2004 | 04:51 AM
cunha's Avatar
Default Re: who makes cams for the ep3 (JdMB16Ahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">only thing with the headswap is ur gonna be making power in a different part of the rpm range....and with the si 5 speed not gonna be making use of the power....so what im getting at a headswap is not the most economical way of making u go faster...yes more power is good but if u can use it why bother...and 2 the a3 bottom end just isnt great as most know. So if u want to upgrade the head great but then u have a great head that can rev to 8k but a bottom end that could take a ****.... Probably wont but could....so u may want to just get the cams which will keep ur powerband where u want it....upgrade ur springs and retainers....get the hondata k pro or something to that effect and stick with the 5 speed.....or get the whole typeS motor/6 speed and be done with it then get cams and everything for that...but its ur money so use it wisely plan ahead wish i did a long time ago....starting to do things right the first time makes it alot less stressful in the end even if it takes longer you'll be happier with the results</TD></TR></TABLE>
What he said.
Check this EPHatch.com thread out:
http://www.ephatch.com/forum/showthread.php?t=47322
Old Sep 20, 2004 | 10:11 AM
thanks guys i really apreciate it
Old Sep 20, 2004 | 05:17 PM
khunt0012's Avatar
Also if you don't feel like swapping the whole head, cams are a good idea, althought it's not a whole lot more work to do the full head. JDMB16A makes a very good point to consider aswell.
Old Sep 20, 2004 | 08:38 PM
redronin22's Avatar
it would be useless to swap cams since a3's only have the intake cam doing any sort of phasing.
Old Sep 21, 2004 | 03:21 AM
Mugen Dom's Avatar
Default Re: who makes cams for the ep3 (redronin22)
hes not talking about cams from an k20a or a2 hes talking about aftermarket cams and using aftermarket cams would be benifactual....id be like putting cams on any other car they are made specific for that engine and u can upgrade the springs and retainers using parts for the k20a or s2k from what ive seen
Old Sep 22, 2004 | 02:40 PM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">hes not talking about cams from an k20a or a2 hes talking about aftermarket cams and using aftermarket cams would be benifactual....id be like putting cams on any other car they are made specific for that engine and u can upgrade the springs and retainers using parts for the k20a or s2k from what ive seen</TD></TR></TABLE>
Thank you, someone understands. lol.
2000EKCoupe
20
Feb 15, 2012 12:52 AM
btk2334
May 26, 2008 08:33 AM
regamaster
39
Aug 19, 2004 08:19 PM
1bad-eg
Jan 20, 2003 08:44 AM
