$400 homemade turbo kit
Old Sep 18, 2004 | 06:13 PM
egizzle8
Guest
Posts: n/a
Default $400 homemade turbo kit
Well I finally finished my turbo kit which set me back a grand total 409! I made alot of the stuff myself so it saved me alot of money and headaches. This is my second kit and the first one I bought was pretty much all made so I can't take credit for it and didn't really work the greatest. Now I'm happy as a teenager after seeing his first porno. the IHI turbo comes with a goofy flange so I decided to weld a T3 flange right over the top of the other one. I'll explain later why. Next the manifold was a old Y7 exhaust manifold that has the cat built right onto it. So I took and cut off the cat and welded on a T3 flange and onto the turbo so when I wanna upgrade I don't need a new manifold too. I sprayed the mani with high temp alum. paint and wrapped it in some leftover DEI header wrap I had leftover. I had some spare exhaust hangers laying around and welded those onto the flange to give it alittle more strength just incase. Overall for $409 at the most I'm pretty satisfied with my results. I hit 12.6 psi today after installing new plugs(one step colder NGK over stock) and retarding the timing and she pulls all the way to redline and is at full boost by 3.5-4k with no bogging or stalling stuttering and no check engine lights. Oh yeah!
Specs
-IHI RHB5 VF $50 junkyard
-Modded Y7 exhaust mani with T3 flange $16 ebay (T3 flange)
-modded 2G DSM SMIC $40 ebay
-exhaust piping for DP & chargepipes, couplers $40 menards & Autozone
-Monza BOV(and chargepipe) & Greddy blubox $125 HMT member
-Blitz dual turbo time/boost gauge $50 ebay
-Cheapturbolines.com oil line kit $78
-NGK plugs $10
HMT OWNZ! Just goes to show you don't need alot of money to be boosted and quality at that.
Old Sep 18, 2004 | 06:25 PM
grappler's Avatar
Default Re: $400 homemade turbo kit (egizzle6)
GREAT!
Old Sep 18, 2004 | 06:26 PM
egizzle8
Guest
Posts: n/a
Default Re: $400 homemade turbo kit (grappler)
Tony the tiger said the same thing!
Old Sep 18, 2004 | 06:27 PM
1boostedcivic's Avatar
threads like this make me hate myself for spending 1000's of dollars on my setup
good work though
Old Sep 18, 2004 | 06:28 PM
hondaguyef's Avatar
Good stuff man
Any pics of the SMIC mounted?
Phil
Old Sep 18, 2004 | 06:30 PM
egizzle8
Guest
Posts: n/a
Default Re: $400 homemade turbo kit (hondaguyef)
I couldn't get a good pic of the smic. It's mounted right where the resonator box on the stock intake goes. I had to cut off on endtank, rotate it and then I JB welded it on. JB weld ownz too! Don't worry that's the only thing that got JB weld
Old Sep 18, 2004 | 06:39 PM
The Destroyer's Avatar
Looks like a sweet setup, what are you using for engine management?
:::Edit, nvm I see you have the blue box. Isnt that for fuel management?
Old Sep 18, 2004 | 06:41 PM
egizzle8
Guest
Posts: n/a
Greddy bluebox. No problems with it so I'm not gonna change it for uber or afc hack for the time being. This is on a P06 w/d16y7 and z6 intake stuff in a 92 dx hatch. Only thing that sucks is that my y8 tranny took a **** so I had to find something quick so I picked up a CX(ewwwww) for $20 locally. First and second aren't bad but everything after that is horrible. next on the list is a new clutch and a z6 tranny.
Modified by egizzle6 at 10:51 PM 9/18/2004
Old Sep 18, 2004 | 07:00 PM
bonestockls's Avatar
good job on piecing together a low buck kit that works for ya. I'm definitely going to be thrifty , but thorough with my setup also.....that way I can buy more beer
Old Sep 18, 2004 | 09:10 PM
Tad's Avatar
Tad
good luck running that 12lbs man..
just remember what motor ur running.
congrats on savin all that dough tough.
Old Sep 18, 2004 | 09:25 PM
ComputerJLT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">Greddy bluebox. No problems with it so I'm not gonna change it for uber or afc hack for the time being. This is on a P06 w/d16y7 and z6 intake stuff in a 92 dx hatch. Only thing that sucks is that my y8 tranny took a **** so I had to find something quick so I picked up a CX(ewwwww) for $20 locally. First and second aren't bad but everything after that is horrible. next on the list is a new clutch and a z6 tranny.
Modified by egizzle6 at 10:51 PM 9/18/2004</TD></TR></TABLE>
what the **** man
http://www.ecimulti.org/uberdata &gt; YUO!!!!
Old Sep 18, 2004 | 10:15 PM
ILuvJDMITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote"> Only thing that sucks is that my y8 tranny took a **** so I had to find something quick so I picked up a CX(ewwwww) for $20 locally. First and second aren't bad but everything after that is horrible
Gm syncromesh friction modified tranny fluid will help carry you through till you replace it
artxdark
Welding / Fabrication
Apr 19, 2014 09:12 PM
1991ls_crx_si
Jan 8, 2009 06:25 AM
Neukin
Mar 1, 2005 09:07 PM
Nextelbuddy
Jun 9, 2003 02:21 PM
technine
Nov 6, 2002 02:21 PM
