boost h22 or h23 ? ? ?
Old Sep 18, 2004 | 05:19 PM
NeKe1point0's Avatar
Default boost h22 or h23 ? ? ?
I have finally got everything set up and enough money for a swap and some boost and minor internals .... a local turbo shop recomended a h23 b.c lower comp??? i was thinkin h22 with fidanza fly, act clutch and sleeve the block for now wish i had mo money for internals ! ! has any one here boosted an h23 and what were the numbers it put up compared to an h22 boosted ? need some advice!
Old Sep 18, 2004 | 05:21 PM
SuperSlow's Avatar
Default Re: boost h22 or h23 ? ? ? (NeKe1point0)
Boosted h23 will give you less headache.
fully built, 450 whp is def. possible.
Old Sep 18, 2004 | 05:29 PM
Default Re: boost h22 or h23 ? ? ? (SuperSlow)
a friend of mine has an Teg... built Ls.Vtec with T3/T4 turbonetics and because so high comp. he runs real low boost 7 pounds any higher and it renigs... and thats what the guy at the turbo shop said too, not a good idea to run high comp vtec with boost.... just wanted to see what everyone else thought...
Old Sep 18, 2004 | 05:53 PM
SuperSlow's Avatar
If you are going to run safe boost you will have to sleeve and build anyway, so why not go with lower compression on the rebuild? anyway, you will get a ton of power on either if you build and tune...
Old Sep 18, 2004 | 06:08 PM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Boosted h23 will give you less headache.</TD></TR></TABLE>
Only if its not a built H22. Built, both engines will be comparable. You could just save more money and get all your internals done at the same time. It beats blowing it up and starting over.
Old Sep 18, 2004 | 06:17 PM
TxTuner
Guest
Posts: n/a
Default Re: boost h22 or h23 ? ? ? (JDMAccord2nr)
H22's are fine to boost as long as you go with a lower compression piston And definitely beef up those internals if your running anything over 7 pounds of boost
Old Sep 18, 2004 | 08:04 PM
TOAB's Avatar
imo if youre leaning toward and h23, go h23 tranny and a jdm dohc f22b. make the same power, and the guts on the f will give you a bit more money to play around with.
Dabrybry
Apr 17, 2009 11:45 AM
BLACK_DEL_SOL
Aug 19, 2004 04:44 AM
SuperShale
Feb 3, 2004 09:27 PM
psyphre
Nov 11, 2002 07:59 PM
H23A1LUDE
Jul 11, 2002 07:13 PM
