** Help me! I am installing my USDM ITR rear sway and a bolt wont go in!
Old Sep 18, 2004 | 04:38 PM
Hulkmanj99's Avatar
Default ** Help me! I am installing my USDM ITR rear sway and a bolt wont go in!
I just got done installing my USDM ITR rear sway bar on. everything went OKAY.....untill i got to the driver side end link.....the bolt wont go through and link up with the welded nut on the other side. i dont know how to get them to line up....i tried to put the car down, raise one side, raise both side, raise the other side....its just not lining up....here a pick if someone can help!
Not lining up
Old Sep 18, 2004 | 04:42 PM
W.O.P.'s Avatar
Default Re: ** Help me! I am installing my USDM ITR rear sway and a bolt wont go in! (Hulkmanj99)
something looks bent to me
Old Sep 18, 2004 | 04:45 PM
Hulkmanj99's Avatar
Default Re: ** Help me! I am installing my USDM ITR rear sway and a bolt wont go in! (1quickLS)
i dont think its bent, cause the bracket thingy looks parallel to each other, and the sway is okay....dont think the bolts bent....but i dont know! i dont want to take it out.
Old Sep 18, 2004 | 04:46 PM
CalGSR99's Avatar
I believe you need to buy some other hardware to make it fit. I read it here on H-T and i belive it was called something like BBK kit. I'm sure you can buy it at home depot but there is other hardware to make it fit.
Old Sep 18, 2004 | 04:53 PM
Dan GSR's Avatar
looks like you just need to move the sway bar over a bit to the driver side
Old Sep 18, 2004 | 04:56 PM
W.O.P.'s Avatar
the sway looks bent out to the left to me if you push it towards the passenger side, it woll fit.
Old Sep 18, 2004 | 05:06 PM
Hulkmanj99's Avatar
i cant just push it.....shold i loosen all the other bolts maybe? and then try? i had the hardware kit....the spacers and plate thingy! but i just dont know why its not fitting....ill loosen everything up and see
Old Sep 18, 2004 | 05:13 PM
EdoMoto's Avatar
Can you take a pic a little farther away? get more of the swaybar in the pic. I think something is wrong with it.
Old Sep 18, 2004 | 05:17 PM
JDMorgan's Avatar
losen the bolt in the lca and pull the swing arm outward and hammer it in.
Old Sep 18, 2004 | 05:21 PM
Hulkmanj99's Avatar
Default Re: (KraZEtEggIE)
i just gave me camera to my friend to load pics of his car at his house....man this sucks....so loosen the lower control connector thingy....not the whole arm right?
Modified by Hulkmanj99 at 12:00 AM 9/19/2004
Old Sep 18, 2004 | 05:29 PM
milo's Avatar
Default Re: (Hulkmanj99)
do the swaybar bolt first, then the lca bolt..
Old Sep 18, 2004 | 06:04 PM
Dan GSR's Avatar
Default Re: (milo)
loosen the 4 bolts circled in red
and move the whole swaybar over so that the endlink doesn't have to be crooked
Old Sep 18, 2004 | 06:07 PM
cjohnson_2's Avatar
Default Re: (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">loosen the 4 bolts circled in red
you did that in the middle of winter? thats hardcore man!
Old Sep 18, 2004 | 06:17 PM
NUBREED's Avatar
Wow..Now that's dedication!!!
Old Sep 18, 2004 | 06:42 PM
W.O.P.'s Avatar
Default Re: (NUBREED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUBREED &raquo;</TD></TR><TR><TD CLASS="quote">Wow..Now that's dedication!!!
</TD></TR></TABLE> word
Old Sep 18, 2004 | 06:58 PM
Dan GSR's Avatar
Default Re: (1quickLS)
&lt;---- if you cut me, I will bleed Honda
Old Sep 18, 2004 | 08:34 PM
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">&lt;---- if you cut me, I will bleed Honda </TD></TR></TABLE>
but if u get cut in the winter u dont even feel it anyways. i was puttin a bodykit on in the winter and when i was pullin a plastc piece off i must have cut my hand pretty bad cuz i looked down and my rad support was covered in blood. lol
Old Sep 18, 2004 | 09:03 PM
Hulkmanj99's Avatar
aright thanks for the advice...i will try that tmrw morning when i wake up. i just put it up on jack stands to keep the pressure of of it....plus i dont want the bolt thats 1/2 in to bend!! thanks guys i will let you know tmrw if it works or not!!
Old Sep 18, 2004 | 10:27 PM
IN VTEC's Avatar
Default Re: (milo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milo &raquo;</TD></TR><TR><TD CLASS="quote">do the swaybar bolt first, then the lca bolt..</TD></TR></TABLE>
You tell 'em Big Rand. That would have been my first suggestion as well.
Mine has the issue where it won't perfectly line up when the suspension is at full drooop. It's not a problem when I have the Tein's installed, but it gets troublesome at times if I have the ITR suspension in.
Old Sep 19, 2004 | 09:42 AM
Hulkmanj99's Avatar
Default Re: (IN VTEC)
i did put the sway on first, then the passenget side LCA and now the driver side LCA wont go in....im gonna loosen them and try to shift it....and then if that doesnt work i will jack the LCA up....i just woek up!
Old Sep 19, 2004 | 09:48 AM
deejaycherub's Avatar
use a phillips screw driver and it through the other side, using it as a lead, lining up the sway and hole... maybe that would help
Old Sep 19, 2004 | 09:57 AM
ragejed's Avatar
Default Re: (deejaycherub)
Hey noobs, Take a good look. He mounted the swaybar upside down. Took you guys forever to figure that out
As for the original poster: Just flip the bar around man and your all set!
Modified by ragejed at 2:27 PM 9/19/2004
Old Sep 19, 2004 | 10:02 AM
iH8RICERZ's Avatar
Default Re: (ragejed)
holy crap! is that snow?! Its been in the 90's where I'm at...still feels like summer *except for today..a little overcast and a lot cooler......* definately dedication!
Old Sep 19, 2004 | 10:35 AM
Hulkmanj99's Avatar
Default Re: (iH8RICERZ)
aright everyone laugh at jamison (ME) for being a n00b, and puttin in a ITR rear sway with a hang over...i put it in upside down! whew well i got some work to do!
Old Sep 19, 2004 | 11:11 AM
ophdehEEzY
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">Hey noobs, Take a good look. He mounted the swaybar upside down. Took you guys forever to figure that out
Modified by ragejed at 2:27 PM 9/19/2004</TD></TR></TABLE>
HAHAHAH
When I first the saw the pic, I was though... "Hmm.. The damn swaybar is upside down!!"
Then I kept reading and reading cus SOMEONE had to have replied already stating it was upside down. rageged, congratulations.. u saw this thread before me!
Damn newbs!
