How do you get "base" ignition timing on a '96 Prelude VTEC?
Old Sep 18, 2004 | 02:45 PM
CBR's Avatar
CBR
Default How do you get "base" ignition timing on a '96 Prelude VTEC?
I know on the older Honda's, you would jumper a connector together. It's been a while since I've checked ignition timing on my Prelude. Does anyone know if there is a jumper connector somewhere that needs to be connected before being able to adjust my ignition timing?
Thanks!
Old Sep 18, 2004 | 03:34 PM
99_SH's Avatar
Default Re: How do you get "base" ignition timing on a '96 Prelude VTEC? (CBR)
Sorry you can't adjust timing. On OBDII cars the timing is set by the ECU, and if you alter it, the ECU will compensate for it.
If you did have an OBDI car then you would just loosen the distributor and turn it to advance timing. No jumpers to connect for preludes
As I said, its not going to work on a 96'
Old Sep 18, 2004 | 04:33 PM
CBR's Avatar
CBR
Default Re: How do you get "base" ignition timing on a '96 Prelude VTEC? (99_SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_SH &raquo;</TD></TR><TR><TD CLASS="quote">Sorry you can't adjust timing. On OBDII cars the timing is set by the ECU, and if you alter it, the ECU will compensate for it.
As I said, its not going to work on a 96'</TD></TR></TABLE>
I kind of figured. Can someone else second this?
Old Sep 18, 2004 | 04:42 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBR &raquo;</TD></TR><TR><TD CLASS="quote">
I kind of figured. Can someone else second this?</TD></TR></TABLE>
Yup; 96 is the first year they implemented OBDII, and as said previously, it did not allow you to change the static timing by rotating the distributor.
Old Sep 18, 2004 | 06:21 PM
safe driver's Avatar
Default Re: How do you get "base" ignition timing on a '96 Prelude VTEC? (LudeyKrus)
I believe the Helms manual says to replace the ECM if the timing is wacked.
david90
Feb 17, 2021 05:58 AM
eg grom
Jun 25, 2009 09:27 PM
flanker
10
May 23, 2008 09:02 PM
Daniel
Aug 22, 2003 07:05 PM
[HrZn]4life
Aug 8, 2002 07:39 AM
