Clutch engagement point on '00 Si
Old Sep 18, 2004 | 12:46 PM
Electron00Si's Avatar
Default Clutch engagement point on '00 Si
The clutch on my Si doesn't engage until the pedal is almost all the way out.... I find this pretty annoying and tough to get used to, especially since all my other cars engage right off the floor.
Is there a way to adjust the engagement point?
Old Sep 18, 2004 | 01:39 PM
Slopoke's Avatar
Default Re: Clutch engagement point on '00 Si (Electron00Si)
Your clutch system is a hydraulic one, so you cannot adjust it.
Its possible that your clutch slave cylinder needs bled or maybe its time for a new clutch.
Old Sep 18, 2004 | 01:49 PM
Default Re: Clutch engagement point on '00 Si (Slopoke)
Well when it grabs, it grabs fine, so I don't think it's slipping and in need of replacement too much.
Every Civic I've driven actually has had the high clutch engagement point... I just find it annoying and wanted to see if there was some way to change it.
Old Sep 19, 2004 | 11:31 AM
asubennett's Avatar
You can adjust a hydro clutch. Under the dash where the rod goes in and out of the master cylinder there is a locknut. In the helms manual it is locknut C.
You can loosen that nut and thread the rod further into the master cylinder or further out depending on the desired result.
Old Sep 19, 2004 | 12:06 PM
senpai's Avatar
Default Re: Clutch engagement point on '00 Si (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">You can adjust a hydro clutch. Under the dash where the rod goes in and out of the master cylinder there is a locknut. In the helms manual it is locknut C.
You can loosen that nut and thread the rod further into the master cylinder or further out depending on the desired result. </TD></TR></TABLE>
Correct answer
NxCmp
Honda Civic (2006 - 2015)
Jul 19, 2012 05:12 PM
krysted9354
Dec 30, 2008 09:19 PM
Boostin_GSR
Jun 3, 2007 11:34 AM
EKDreamin
Apr 30, 2006 02:56 PM
redsikiller
Dec 2, 2005 08:58 AM
