98-up integra on eibach sportlines??
i installed my sportlines a while ago and i was wondering if anyone else is having the same problems as me.. its a 98 teg LS.
number 1- the drop is rediculously uneven, the front is noticeably higfher up front- normal? the back tucks pretty well
number 2- the spring isnt stiff at all. i know they are progressive springs and they tighten as they are stressed, but stationary they are as bouncy and give justr as easily as stockers.. normal?
anyone with experience with these care to help me out with some information... much appreciated.
yes the front is noticeably higher up front. i hate it. but its a comfortable ride imo. i like the feel of it.
get shocks that you can perch and that should solve your hieght prob, correct me if im wrong
make sure all of your bushings and factory hardware is in the right place....and did you cut your bumpstops? i always cut mine in half and they seem to do fine...i had some sportlines that came on a car i bought ...the rear was missing 1 rubber bushing, both metal tube collars, and the bumpstops werent cut in the front....i replaced all of the missing peices, cut the bumpstops, and now its great.....might wanna check yours and do the same
okay, im gonna go check that right now.. thanks for the help.
the sportlines usually have such a nice drop, i was really dissapointed. I'd hate to see what the pro-kit looks like
From: im nothing from no where im no one at all, ca
i got some eibachs on my 94 teggy too. they came off a 97 civic. he didnt like them cause they were to high and i didnt like my neuspeed race springs cause they were too low. so we switched and i love the way my car feels now. its so smmmoooottthhhh over bumps. and now also i dont have to worry about hit stuff under my car. its alot better. before with the old springs both front and back wheels were tucking, and they were 16's with, now there's about an inch between the fender well and the tire. eibachs are worth it.
i hate that! if i cared about a smooth ride i would have kept my stockers!
i spent good money and i <U>want</U> to have to worry about bumps! i wanna go over speedbumps sideways! i wanna be stiff as a motherfockner damn it!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood »</TD></TR><TR><TD CLASS="quote">i hate that! if i cared about a smooth ride i would have kept my stockers!
Sounds like you want groundcontrols with a specified spring rate, or something else you can choose to be super stiff. If this springs are the same as for a 00 gsr, then sell em to me and go get yourself some stiff *** springs or coil-overs.
</TD></TR></TABLE>Sounds like you want groundcontrols with a specified spring rate, or something else you can choose to be super stiff. If this springs are the same as for a 00 gsr, then sell em to me and go get yourself some stiff *** springs or coil-overs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood »</TD></TR><TR><TD CLASS="quote">number 1- the drop is rediculously uneven, the front is noticeably higfher up front- normal? the back tucks pretty well</TD></TR></TABLE>
You might consider switching the rear springs with the front ones... this could solve your problem of the front end looking "jacked up" and should also help induce oversteer (assuming Eibach designed the front springs to be stiffer than the rear ones as most manufacturers seem to do)... just an idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesb18c »</TD></TR><TR><TD CLASS="quote">
You might consider switching the rear springs with the front ones... this could solve your problem of the front end looking "jacked up" and should also help induce oversteer (assuming Eibach designed the front springs to be stiffer than the rear ones as most manufacturers seem to do)... just an idea.</TD></TR></TABLE>
i did that already its still all messed up looking but the ride is smooth feels like stock
sohcpoweredeg
33
Sep 22, 2011 05:36 AM
