air/fuel ratio gauge which wire on the ecu i tap into
Old Sep 18, 2004 | 10:05 AM
boostng r's Avatar
a
Default air/fuel ratio gauge which wire on the ecu i tap into
its a autometer which wire on the ecu harness do i tap into thanks
Old Sep 18, 2004 | 10:21 AM
Luserkid's Avatar
Default Re: air/fuel ratio gauge which wire on the ecu i tap into (b16coupe4)
I tapped mine into the white wire on the o2 sensor.
Old Sep 18, 2004 | 10:46 AM
saleensolution's Avatar
Default Re: air/fuel ratio gauge which wire on the ecu i tap into (Luserkid)
if you go to the ecu the wire that you need to spice into is D14 which is a white wire
Old Sep 18, 2004 | 10:57 AM
ecahatch's Avatar
Senor Miembro
white wire...its most likely thicker than the rest of the wires
chrisfromsrq
Jul 30, 2009 09:47 AM
92prelude23
Nov 17, 2008 02:09 PM
Wannabe JDM
14
Nov 26, 2005 11:25 AM
Tad
23
Nov 13, 2003 11:24 AM
BlackB18CTeg
Apr 5, 2003 09:14 PM
