Help, How Do You Reinstall Tranny Fluid?? Pic?
Old Sep 18, 2004 | 09:37 AM
Traction's Avatar
Default Help, How Do You Reinstall Tranny Fluid?? Pic?
I got the **** out no problem, now Im trying to get my car back together and I dont see where you would put it back in.
Pics would help, thanks
Old Sep 18, 2004 | 09:40 AM
crexer's Avatar
Default Re: Help, How Do You Reinstall Tranny Fluid?? Pic? (Traction)
You can put it in from the speedo cable plug in with like a silicon hose or a pump type thing...also their is a plug on top of the tranny. try using your moms turkey baster!!
Modified by crexer at 1:59 PM 9/18/2004
Old Sep 18, 2004 | 09:53 AM
EF-EF's Avatar
thats what i did.
Old Sep 18, 2004 | 09:59 AM
Traction's Avatar
Default Re: (EF-EF)
the speedo cable plug is right in the back of the tranny right? Like right near the firewall?
Pic?
I dont have to have to have the car done until tonight and this and putting the wheels back on is all thats left
Is it just unplugging this cable and refilling the fluid till it seeps out?
Old Sep 18, 2004 | 10:01 AM
crexer's Avatar
Default Re: (Traction)
if its a cable tranny you will see the speedo cable running from the firewall to the top of the tranny and just unplug it without loosing the clip that holds it in and fill her up
Old Sep 18, 2004 | 10:10 AM
Traction's Avatar
Default Re: (crexer)
thank u
Old Sep 18, 2004 | 12:05 PM
EVOLUTIONINNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">also their is a plug on top of the tranny.</TD></TR></TABLE>
pic?
Old Sep 18, 2004 | 12:10 PM
bambam's Avatar
I've NEVER heard of filling ur tranny with fluid at the speedo drive inlet....until it overflows. The actual designated area to fill ur tranny with fluid is on the back left side of the tranny (if looking at the tranny from the passenger side wheel well). It should be a 17mm plug like ur oil pan plug.
Old Sep 18, 2004 | 12:14 PM
crexer's Avatar
Default Re: (bambam)
here i searched for you guys.....wasnt that hard....and yes more than just me fills through the VSS hole....all goes to the same place....pics are on this link https://honda-tech.com/zerothread?id=851527
Old Sep 18, 2004 | 12:43 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">here i searched for you guys.....wasnt that hard....and yes more than just me fills through the VSS hole....all goes to the same place....pics are on this link https://honda-tech.com/zerothread?id=851527</TD></TR></TABLE>
i meant to say that you don't want to fill your tranny fluid up in that hole until it starts to pour out of the vss. You still have to loosen the drain plug on the side of the tranny and wait till it seeps out of the drain plug.
Old Sep 18, 2004 | 03:25 PM
Traction's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">I've NEVER heard of filling ur tranny with fluid at the speedo drive inlet....until it overflows. The actual designated area to fill ur tranny with fluid is on the back left side of the tranny (if looking at the tranny from the passenger side wheel well). It should be a 17mm plug like ur oil pan plug.</TD></TR></TABLE>
DING DING DING
I actually didnt read your post before I went out and tried
I couldnt get the VSS out so I started looking for other **** and I found this guy, poured some fluid in and undid the drain plug, out came the fluid I just poured in, I didnt know how much to put in though, so I just put in what came out lol
I just used a long hose and a funnell
Old Sep 18, 2004 | 07:51 PM
blo2k1's Avatar
2.1 quarts is what the book calls for
Old Sep 18, 2004 | 08:48 PM
Civic138's Avatar
Default Re: (blo2k1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blo2k1 &raquo;</TD></TR><TR><TD CLASS="quote">2.1 quarts is what the book calls for</TD></TR></TABLE>
i thought it was 1.9 quarts in all honda trannys?
Old Sep 18, 2004 | 08:58 PM
senpai's Avatar
Default Re: (Civic138)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was 1.9 quarts in all honda trannys?</TD></TR></TABLE>
here we go again
Old Sep 18, 2004 | 11:52 PM
Reelizmpro's Avatar
What is the tranny fluid of choice? synth? weight?
Old Sep 19, 2004 | 01:11 AM
yellowcrx1991's Avatar
Default Re: Help, How Do You Reinstall Tranny Fluid?? Pic? (Reelizmpro)
People are going to tell you Honda MTF, some will say suggest that if your syncros(late, sp?) grind you should get GM Syncromesh, I personally use Mobile One 10w30.
pinecone
Apr 12, 2006 01:26 PM
JSPECCRX
Oct 25, 2004 10:57 PM
