b18c1 swap question.
Ok, im doing a GSR swap into my EK and was told the only mount i would have to replace would be the timing belt mount that i would have to get from an Si cause its the only one that would work? is this correct or can i use the timing belt mountfrom my SOHC? someone please help me out. I searched for a few timing belt but came up empty handed. Any help would be appreciated.
-albert
-albert
use a rear transmission mount from a 99-00 si, a driver side top mount from 99-00 si, and reuse your stock top transmission mount, im guessing the torque mounts will have to be from a 99-00 si , but i know for a fact the rest are correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eclypzex »</TD></TR><TR><TD CLASS="quote">so my SOHC timing belt mount would work? or do i have to buy all Si mounts?</TD></TR></TABLE>
The mount itself is fine, it's the bracket that you need to replace.
You can reuse your stock civic fluid filled mount that sits on the chassis.
The bracket that goes between that fluid filled mount and the mount bolted to the block needs to be from the civic si.
Also the rear tranny bracket needs to be from the si.
The lower tranny mount and the ac bracket can be from any '94-up B series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">
The lower tranny mount and the ac bracket can be from any '94-up B series.</TD></TR></TABLE>
this is correct..but if you want it to be perfect, on the ac bracket and lower tranny mounts you'll need to use the civic mounts w/ the b series brackets.
sikcivic95
May 13, 2008 08:18 PM
swappedcx
Dec 24, 2005 04:11 AM
