Dash BRAKE idiot light
The light came on the other day for a few minutes. When i tapped the brake pedal it went out... then came back on. It did this for 1 trip on a cool morning. I was out again today, and it is cool again, and the same thing happened. What logic makes up that brake idiot light? And yes.. the fluid level is fine!!
Check the adjustment of your parking brake cable. Pull off the center console and take a look at it. I know if it's too tight, it may cause the brake light to come on. I think this is what you are reffering to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sys3rror »</TD></TR><TR><TD CLASS="quote">your brake fluid level could be low</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grngsr01 »</TD></TR><TR><TD CLASS="quote"> And yes.. the fluid level is fine!!
did you not read his post? damn n00b.. 1000+ post's or not..
could there be any air in the brake system?
try everyones idea's on here, im sure someone said the solution..
what have you tried/checked out?
ive got the same problem. i havent checked my brake fluid yet, but im pretty damn sure thats it. i got the car with **** brakes apparently THANKS RIVERSIDE ACURA POS. anyway, im going to do a flush and get new rotors and pads. one of the rotors was warped when i bought it and they "lucky for me" resurfaced it no charge.
except i have no money now, so.. might be a little while
As I posted above. 97-01 integras have a problem with the filter in the brake master cylinder resevoir. Take out this filter and see if the problem goes away. Clean it if it has gunk in it.
I had the same probelm.
shocker911
Oct 7, 2010 04:24 PM
ismellskunk
Jun 4, 2006 02:35 PM
mashoutposse
Sep 5, 2005 01:05 PM
