ZC exhaust manifold
Old Dec 10, 2001 | 05:51 AM
frank5079's Avatar
Default ZC exhaust manifold
I've found a ZC exhaust manifold for my '87 teg motor; which downpipe will fit this manifold? BTW the teg motor is in my '84 CRX.
Thanks guys.
Old Dec 10, 2001 | 06:41 AM
rainforest's Avatar
Default Re: ZC exhaust manifold (frank5079)
yours
Old Dec 11, 2001 | 08:23 AM
frank5079's Avatar
Default Re: ZC exhaust manifold (rainforest)
The ZC manifold has two openings; the teg, only one. No matter because I've found one from a Civic. Only problem is the flange is angled too high. I'm going to try to modify it by cutting the twin pipes at the bend, angling them downward and adding a three or four inch section of pipes to lengthen them somewhat as well as welding a new O2 sensor bung at the junction because the stock O2 sensor location is behind the manifold and trying to replace the sensor will be next to impossible.
.Manny.
May 26, 2006 04:11 PM
hondacivic4g
May 12, 2005 10:56 PM
R6Boy69
Aug 22, 2001 08:48 AM
Alphahelix
Aug 1, 2001 06:00 PM
