supercharger on sohc
Old Sep 17, 2004 | 10:12 PM
H.A.R.T b16a1crx's Avatar
Default supercharger on sohc
anyone with jackson racing supercharger, im hearing that you can only put a 10 psi pulley on it. is this true? how far can you go on these?
Old Sep 17, 2004 | 10:23 PM
AGENT 99's Avatar
Default Re: supercharger on sohc (H.A.R.T b16a1crx)
being non intercooled, I dont think you would want to push more than 10. If your looking for more power, go turbo. I think they come with a 6lb stock, which makes 40 more at the wheels.
good luck
Old Sep 17, 2004 | 10:46 PM
95dxhatch's Avatar
which motor is this going on? there was a guy on the boards here who ran 10lbs on his d15b7 (weak block) for just over a year until he put a hole in the block. just dont be stupid with it. turbo will get more power but SC is different than what most do. anything else? i was looking at doing this to my sohc but that's on hold for now while i'm going to school.
jdm123's Avatar
just go turbo with mad boost yo
Old Sep 17, 2004 | 10:48 PM
Default Re: supercharger on sohc (jdm123)
i went turbo and blew motor so im kinda scared this time around
Old Sep 17, 2004 | 10:49 PM
BatuKing's Avatar
Just stick with a 8lb pulley at max. I mean if your looking to get the most power out of your motor the JRSC is not the answer, but if your like me and just want decent power then tune it via Uberdata and be happy
Old Sep 17, 2004 | 11:13 PM
AGENT 99's Avatar
Default Re: supercharger on sohc (BatuKing)
why did your turbo blow the motor? What fuel mgt were you running?
Old Sep 17, 2004 | 11:24 PM
95dxhatch's Avatar
turbo is all about proper tuning, good setup and maintenence. what motor was all this on again or what you've got now?
Old Sep 17, 2004 | 11:27 PM
CRX_1.8T's Avatar
i had a JRSC on my SOHC engine (79k miles). it was fun to drive and sounded beautiful, but it wasn't quite what i wanted.
as for 10psi being the limit i would definetely say so. i think that if you take it too far you could end up with an explosive mess of castor bean oil and broken pulley belts.
my friend ported his blower and says it made a difference.
Old Sep 18, 2004 | 12:40 AM
murmur9's Avatar
Default Re: supercharger on sohc (CRX_1.8T)
turbo
Old Sep 18, 2004 | 09:21 PM
Default Re: supercharger on sohc (murmur9)
well i had a y8 and i just swaped a y8, i was running a damn fmu and i was detonating.
Old Sep 18, 2004 | 10:41 PM
murmur9's Avatar
how big of injectors
Old Sep 19, 2004 | 08:55 AM
stock injectors
Old Sep 19, 2004 | 09:56 AM
JDMisGOOD's Avatar
JUST GO TURBO!
Old Sep 19, 2004 | 10:05 AM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T b16a1crx &raquo;</TD></TR><TR><TD CLASS="quote">well i had a y8 and i just swaped a y8, i was running a damn fmu and i was detonating.</TD></TR></TABLE>
just run hondata or uberdata or at least vafc hack, even if youre running low boost you will make more power than a JRSC will
Old Sep 19, 2004 | 12:08 PM
jdm123's Avatar
Default Re: supercharger on sohc (Art In Motion)
the jr superchargers don't do very much for the soch ecspecially for the amount of money you would be puttin down for it.
Old Sep 19, 2004 | 12:12 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
go with turbo on a honda because of its high revving capabilities.
leebo
Honda Fit
Apr 15, 2007 06:52 PM
Snate
Dec 18, 2006 03:18 PM
krazeemidget
Feb 20, 2004 11:36 PM
kHoA DoGG
May 22, 2003 07:38 AM
M.A.R.C.
May 1, 2002 11:42 PM
