Wring diagram
i had to get this from a pdf. file so you'll have to print these out, then paste them together. i gave you a small overview of what the diagram looks like, but when you paste them together, the order should be
01 03
02 04
i also circled where the pictures overlap with coordinating colors. so just connect those together and that should also help you put the diagram together.
Overview:
http://www.we-todd-did-racing....D.jpg
01:
02:
03:
04:
I hope i didnt confuse you too much.
James
01 03
02 04
Overview:
01:
02:
03:
04:
James
Wiring pinouts for the CRX/Civic (remember that the 88-89 are different from the 90-91):
https://honda-tech.com/zerothread?id=709958
Wiring of the VSS...
https://honda-tech.com/zero...55473
Pinouts of the earlier 94+ tegs. (The 2001s are slightly different)...
http://oregonstate.edu/~uyemur...s.pdf
im assuming you are putting a teg gauge cluster in your crx. I just got done doing it hope that helps
hey, ya this helps alot, but the third site(Pinouts of the earlier 94+ tegs. The 2001s are slightly different)... doesnt open right for me, says page error, if you could send a link that works for this one, that would be awesome, to see what the 94 teg pin outs are. thanks
NAK20
Engine Management and Tuning
Oct 6, 2018 05:19 AM
