mis-shifted last night :(
Old Dec 10, 2001 | 04:11 AM
turbopyitr's Avatar
New User
Default mis-shifted last night :(
long story short, i shifted from 4th redline to 3rd for half a second. im a good driver so i caught my mis-shift right when it got in for half a second and quickly shifted to neutral. no valves are ticking yet and ive driven it for a good hour after the incident. is it possible i didnt bend a valve? or i did bend one...but its just not clucking right now.
Old Dec 10, 2001 | 04:17 AM
2k1TypeR0610's Avatar
New User
Default Re: mis-shifted last night :( (turbopyitr)
How's your idle?
Old Dec 10, 2001 | 04:52 AM
turbopyitr's Avatar
New User
Default Re: mis-shifted last night :( (2k1TypeR0610)
idle is good, like normal. im scared to take her to redline now. i guess im going to do some easy driving for a week. btw i ran a 14.7 @ 94 mph last night, woot was hoping to get into 14.6 or better but i only got to run once.
[Modified by turbopyitr, 7:53 AM 12/10/2001]
Old Dec 10, 2001 | 05:29 AM
Dr Pooface's Avatar
Did your rpms go over 9k? From everything I've heard, its REAL ****** obvious when a valve is bent.
Old Dec 10, 2001 | 06:53 AM
MyYellowHonda's Avatar
New User
Default Re: mis-shifted last night :( (Dr Pooface)
I have to a little question to ask here.. though i'm slightly afraid to make it a topic on it's own.
I'm still running my engine in, it's under 400k's on the odometer.
Problem is i've been going alittle harder than i should be lately, is this okay? Is it not a serious problem to go too hard on the engine just less frequently while the engine is still running in....?
I've taken it to 6k's regularly, 8k's twice, and 7k's twice. I've never shifted it at 8k's at every gear yet. It's just along the highway i might drop a gear and bring up the rev's abit to catch up with some others.. I'm alittle worried, but i guess it's my fault. Has anyone else found that trying to avoid redlining the beast during break in period is extraordinarily difficult? I certainly have.
But whats the worse that could happen from this?
Sorry for being off topic from the post.
Old Dec 10, 2001 | 08:57 AM
98TypeR's Avatar
Default Re: mis-shifted last night :( (lordastro)
do a compression test. better yet a leak down. If its bent you will hear the hissing. you should be doing better than 14.7 if you have a turbo kit. alot better.
Old Dec 10, 2001 | 09:03 AM
B2FiNiTY's Avatar
Breaking in the car is the worst part about buying a new car. You should be ok just don't get to RPM happy while breaking it in. Take it easy.
Old Dec 10, 2001 | 09:14 AM
Muckman's Avatar
Moderator in Chief
yeah your fine.. I did the same thign in my GSR on the highway.. was trying to show up this newer cav Z24. I was pushing in 4th and thought to myself, damn my car is slow, and dropped it into 3rd without even thinking. Perfect rev match too, Car saw about 9k for maybe only half a sec before I realized how dumb I was and pushed the clutch in. 5k miles later, no problems, no weird noises.
Old Dec 10, 2001 | 09:20 AM
sackdz's Avatar
Default Re: mis-shifted last night :( (Muckman)
How could you do a perfect rev match @ 9000 in a GS-R, isn't fuel cutoff ~8700?
Old Dec 10, 2001 | 10:55 AM
SleepyR's Avatar
New User
I say your car is fine, mechanic at the dealer once told me when I mishifted that you would definately get a check engine light if anything were wrong w/ the engine b/c OBDII is so sensitive to any changes.
Old Dec 10, 2001 | 12:04 PM
thrombosis's Avatar
New User
Default Re: mis-shifted last night :( (SleepyR)
dealers lie
Old Dec 10, 2001 | 01:01 PM
Hukd Up's Avatar
Default Re: mis-shifted last night :( (thrombosis)
sounds like everything is fine......sometimes ppl get lucky.
i bent some valves a while back, and the car was bearly drivable, if your idle is fine, and you haven't heard any weird sounds, i wouldn't worry about valves.....
but with a 1/4 time of 14.7 with a turbo, i'd worry about your setup!
Old Dec 10, 2001 | 01:13 PM
Black SVT's Avatar
Why take it easy for a weak?If it isn't broke don't worry about it.When mine overeved it idled like ****.Another thing that typically happens during and over rev is a bent rod.It is almost always #3.Pull your plugs and check them for any fowling.Good luck
Old Dec 10, 2001 | 01:25 PM
goern-R's Avatar
I had the same "problem" staying off the gas during my break in time. In fact, on my test drive with 63 miles on the car, the salesman insisted that I really get on it to appreciate the car, so I redlined second . That was before I even knew that the car should be broken in properly. 10k miles later, everything is still perfect and running strong. Another girl I know with a type R didn't break hers in at all- hard driving from day 1... still fine.
I wouldn't worry too much.
Old Dec 10, 2001 | 02:20 PM
PMTypeR's Avatar
Default Re: mis-shifted last night :( (GOERNS_PYT-R)
I mis-shifted once and I paid the price for it
2 bent valves
Like they say though. You learn from experience!!!
Old Dec 10, 2001 | 03:20 PM
AllMotorITR's Avatar
New User
A 14.7 with a Turbo !!!! WTF? What turbo are you running? So I can avoid it.
Old Dec 10, 2001 | 03:22 PM
EG8R's Avatar
Default Re: mis-shifted last night :( (PMTypeR)
Sounds like mis-shifting is not the thing to do.... I've never done it, then again my car is a POS and I'm not too worried about it even though when I was driving it would see 6K(redline) quite often
[Modified by mr. skelly, 4:22 PM 12/10/2001]
Old Dec 10, 2001 | 06:36 PM
turbopyitr's Avatar
New User
Default Re: mis-shifted last night :( (mr. skelly)
no turbo yet....all motor, only headers on the car, everything else is stock. going to go turbo in half a year
Old Dec 13, 2001 | 10:02 AM
Muckman's Avatar
Moderator in Chief
Default Re: mis-shifted last night :( (sackdz)
fuel cut off is 8200 in a GSR.. it was 'perfect' in the sense that i was able to downshift into a lower gear from high rpm. It went in like butter, normally id expect the shifter to fight being forced into a lower gear at such an rpm... thats what i meant.... it was gay.. i choose not to remember my bad driving mistakes like that...
Old Dec 13, 2001 | 10:47 AM
nfn15037's Avatar
Um, well, just wait till about 30-40k and your car will be slow. Theres a kid in my hometown who has a PY ITR and he beat on it from day 1. Well, now he runs a 9.9 1/8th mile and his car is slow as crap. Just go easy on it for a few thousand miles, then have some fun.
Old Dec 13, 2001 | 11:40 AM
2005 TSX's Avatar
Default \
Fuel cut off is 8200 in a GSR...
He he he he...I bounced off the limiter in 2nd today, for the first time in my life. Should I be concerned? Maybe I should do a leakdown and compression test just to be safe.
Old Dec 13, 2001 | 11:50 AM
Dirty GS-R's Avatar
New User
Default Re: \ (2001 Integra GSR)
As long as you dont continually bounce it off the limiter you wont have a problem. That's what it's there for.....to keep you from screwing up your engine.
[Modified by 2K1 GS-R, 3:52 PM 12/13/2001]
Old Dec 13, 2001 | 12:38 PM
mad skillz's Avatar
New User
Default Re: \ (2K1 GS-R)
You should monitor the oil closely level too.
OT:
I got happy the other day and went into fuel cut off. I was not paying attention to the tach. (watching traffic). Now I have a buzzer.
JMod
Oct 24, 2005 08:31 PM
jdmBOMEXsi
25
Mar 16, 2005 11:52 PM
94B18B1Teg
Dec 13, 2003 07:51 PM
ALLMOTR_R
Oct 27, 2003 09:38 AM
DIRep972
Mar 7, 2002 12:43 PM
