do 2003 Si wheels fit EG bolt pattern
Old Sep 17, 2004 | 05:01 PM
b18c1delly's Avatar
Default do 2003 Si wheels fit EG bolt pattern
need to know if the new Si wheels fit a del sol wheel pattern
Old Sep 17, 2004 | 05:07 PM
hisownhero's Avatar
Default Re: do 2003 Si wheels fit EG bolt pattern (b18c1delly)
2003 Civic Si wheels are 5 lug ... del sol pattern is 4 lug ... you would need to convert from 4 to 5, then it shouldn't be a prob! Hope that helps!
screech's Avatar
02 and up SI's are 5 lug so how could they possibly fit
http://www.discountedwheelware...e.cfm
*cliff notes
02+ SI 5 x 114.3
All del sol 4 x 100
Old Feb 20, 2005 | 07:16 AM
Pssst!'s Avatar
Default Re: do 2003 Si wheels fit EG bolt pattern (screech)
What about these?
http://www.wheelspecs.com/specs/wheelmodels/1745
Old Feb 20, 2005 | 07:57 AM
Solo2EG's Avatar
Default Re: do 2003 Si wheels fit EG bolt pattern (Pssst!)
yes, those will fit, how quickly we forget that the EP3 Si came with 4 lug first...
Old Feb 20, 2005 | 08:48 AM
DJ_SaNdOz's Avatar
Default Re: do 2003 Si wheels fit EG bolt pattern (Solo2EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2EG &raquo;</TD></TR><TR><TD CLASS="quote">yes, those will fit, how quickly we forget that the EP3 Si came with 4 lug first...</TD></TR></TABLE>
EP3 was 4x100 in 02 wasn't it? I thought that they switched to 5 in 03
Old Feb 20, 2005 | 08:52 AM
r3p00c's Avatar
Default Re: do 2003 Si wheels fit EG bolt pattern (DJ_SaNdOz)
eps were 4x100 for '02 and '03. they switched to the 5-lug setup in '04. you'll be fine with the '03 wheels. trust me... i used to have one. that website listed above is wrong.
LoveBrisk
Feb 22, 2014 06:39 AM
Squallie
14
Sep 12, 2005 03:13 PM
chronodyne28
Jun 17, 2004 06:04 AM
Jan in Omaha
Jan 31, 2004 09:34 PM
scottscotland
Mar 9, 2003 04:32 AM
