Have a few Q's about CD player install
Old Sep 17, 2004 | 02:51 PM
DarkZachiel's Avatar
Default Have a few Q's about CD player install
I have a 2000 Civic Si factory cd player and want to install it into an 88-91 CRX. Now from what I understand the factory stereo harnesses are compatable from 88-97 (I think, not sure). However as the Si stereo is 99-2000 I am pretty sure it won't be plug and play. In a nut shell I guess I am asking what I need to do to make this work. Also I do not have the harness for the Si stereo so I am thinking that I need to get the factory harness for the Si stereo and one of those harnesses from best sbuy or something for the CRX side where it plugs into and splice the wiring but I am not sure so if anyone could fill me in on whether this is right or there is an easier way please let me know. Thanks in advance...
Old Sep 17, 2004 | 09:00 PM
Default Re: Have a few Q's about CD player install (DarkZachiel)
bump
Old Sep 18, 2004 | 08:51 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkZachiel &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE> Metra makes the harness you need 70-xxxx
will plug into the car and 71-xxxx will plug into the HU. 94
Old Sep 20, 2004 | 06:43 PM
I found the two part numbers and I bought them today from best buy. Best Buy actually carries metra products and they had them in stock. Anyway I connected the wiring but there is one orange wire left on the stereo side of the harness and when I checked the color guide it said the orange wire was for "Illumination". since there was no orange wire on the into-car side of the harness I'm wondering if this is actually for the back light on the stereo. What do you think?
Old Sep 22, 2004 | 06:36 PM
bump
Old Sep 23, 2004 | 07:06 PM
anyone?
Old Sep 23, 2004 | 08:09 PM
blueinfinity's Avatar
it probably attaches to your dim switch. have you had it on yet? does it glow? if not try attaching it to the ignition on switch. i thik newer models had a seperate wire for lighting.. older ones used the usualy constant.. so the older car wouldnt have a wire for that.. just a htought im not 100%
Old Sep 24, 2004 | 10:03 PM
ok so now I'm pretty sure that I'm going to have to do something with that lone wire that I mentioned in the post above. So does anyone have any suggestions as to what I should splice that wire into so that the deck will be backlit? I guess it should be spliced into one of the accessorys but I'm not sure which one. any suggestions?
Old Sep 25, 2004 | 10:41 PM
bump?
Old Sep 26, 2004 | 08:56 PM
ok one last bother for you guys. I decided to tap the orange Illumination wire into the red (12v/accessory) wire on the harness itself. Is the gonna work? I need to know before I close everything up and test...thanks in advance
Old Sep 27, 2004 | 09:26 PM
ttt
Old Sep 28, 2004 | 03:05 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkZachiel &raquo;</TD></TR><TR><TD CLASS="quote">ok one last bother for you guys. I decided to tap the orange Illumination wire into the red (12v/accessory) wire on the harness itself. Is the gonna work? I need to know before I close everything up and test...thanks in advance</TD></TR></TABLE> Yes it will. 94
Old Sep 28, 2004 | 06:46 PM
Default Re: Have a few Q's about CD player install (fcm)
yeaH boi. I'm gonna test it tomorrow
Old Sep 29, 2004 | 04:34 PM
audioroach's Avatar
if your rex is has an illuminated light above the cig lighter or ash tray
you can tap that light for your illumination on the radio. Or if not you can
extend it to your fuse panel and tap it into one of the male spades ( one is
tied to your park light circuit)
Old Oct 2, 2004 | 06:29 PM
Default Re: Have a few Q's about CD player install (audioroach)
actually i just tapped it to the red 12v wire on the stereo harness itself. tested and it all works so far...
Old Oct 7, 2004 | 01:35 PM
yellow650's Avatar
does anyone know if the stock 00 Si Cd player has RCA jacks on the back.
what's the best way to splice in my iPod into the player?
can i get an adapter that hooks into the cd-changer input?
crex23
Audio / Security / Video
Oct 28, 2006 02:25 PM
SloCrxDx91
May 16, 2005 02:10 PM
DarkZachiel
Jul 29, 2004 06:27 PM
QUiKSR20
Jul 7, 2004 03:38 AM
UnrealSpeed
11
Jul 21, 2003 11:46 PM
