installed Fastbrakes 11" upgrade w/2pc directional vein rotors
Old Sep 17, 2004 | 02:03 PM
6ghatch's Avatar
Default installed Fastbrakes 11" upgrade w/2pc directional vein rotors
I've been having brake issues with my 99-00 SI brakes on my 97 Hatch. Seems that the 10.2" brakes are just too small for my race car. So I decided to try out the fastbrakes 11 inch upgrade. This includes 2 "ITR" type calipers (I believe mine were 2001 CRV) and 2 piece 11" directional vein rotors.
The kit came with aluminum mounting hats, rotors, hub centric rotor rings, allen bolts and some washers to correctly center the caliper.
I used red loctite on the allen bolts when installing the mounting hats. I also opted to go with the pads I've been running, the Carbotech XP9's
Installation is fairly straight forward, but I'd recommend to get some different thickness washers. I ended up using a slightly thicker washer to properly space the caliper around the rotor. Warning these rotors are THICK!! were talking about caliper clearance in millimeters! You need to take your time to make sure the rotor does not contact the caliper mounting bracket.
The total weight of the brake upgrade is only 3lbs heavier per side then the 99-00 Civic SI rotors and calipers.
I'll update this with a review after my next race.
Modified by 6ghatch at 9:35 PM 9/17/2004
Old Sep 17, 2004 | 02:51 PM
SLow-Side's Avatar
Default Re: installed Fastbrakes 11" upgrade w/2pc directional vein rotors (6ghatch)
Nice setup.
How much did you pay for that complete setup?
Old Sep 17, 2004 | 03:04 PM
JDMisGOOD's Avatar
Default Re: installed Fastbrakes 11" upgrade w/2pc directional vein rotors (civiclizeEg)
ooooooh NOICE!
Old Sep 17, 2004 | 03:06 PM
IM ALL BOB's Avatar
Awesome setup ... if I didn't already have the 11" OEM caliper upgrade I'd be sure to get this...can't wait for the review after your race..just wondering what is the weight of the rotor alone not including the caliper? as my corrado 11" rotors are pretty heavy
Old Sep 17, 2004 | 03:07 PM
6ghatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiclizeEg &raquo;</TD></TR><TR><TD CLASS="quote">Nice setup.
http://www.fastbrakes.com/prod...ecR-2
Rotors go for about $350-$400, calipers about $130, Pads $130.
Old Sep 17, 2004 | 03:22 PM
6ghatch's Avatar
Default Re: installed Fastbrakes 11" upgrade w/2pc directional vein rotors (IM ALL BOB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">Awesome setup ... if I didn't already have the 11" OEM caliper upgrade I'd be sure to get this...can't wait for the review after your race..just wondering what is the weight of the rotor alone not including the caliper? as my corrado 11" rotors are pretty heavy</TD></TR></TABLE>
I didn't weigh the rotors but the web site says they ar 2lbs lighter per rotor then the regular 11".
Old Sep 17, 2004 | 04:22 PM
SLow-Side's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6ghatch &raquo;</TD></TR><TR><TD CLASS="quote">
Rotors go for about $350-$400, calipers about $130, Pads $130. </TD></TR></TABLE>
$350 for both rotors? thats a good deal... I should go pick some up too.. thanks man. Cant wait for review.. want to know how good it really works.
Old Dec 31, 2004 | 10:06 AM
AspectIndustries's Avatar
For everything, seems to be as the price of wilwood big brake kit. Any better?
Been awhile.. I wanna know how it goes.
Old Jul 25, 2005 | 04:16 PM
6ghatch's Avatar
Default Re: installed Fastbrakes 11" upgrade w/2pc directional vein rotors (synik)
Old post but I figured I'd update it.
I had to work out a couple issues but now the brake system is working out great. When I first put them on last season I found the brakes were vibrating so I got the rotors cut before this season and that fixed the issue. I also realized last season that I needed the ITR caliper mounting brackets vs. the CRV's. The CRV brackets didn't have enough width to clear the thick rotors (also the reason I had to use extra washers to space out the caliper) so I tried to file them (which didn't really work) so in the end I picked up the correct ITR caliper mounting brackets. The ITR's are offset properly, wider to fit around the thicker rotor and won't contact the rotor surface.
First race this year was at CMP, a track known for destroying brakes. They were perfect, very little fade. Then a very hot weekend at Summit giving 2 of my fellow H1 racers brake issues, broken rotors ect. Mine seem to be working fine. I'd like to give a quick thanks to Brian at fastbrakes for putting together a great product that actually holds up in real racing scenarios.
Modified by 6ghatch at 7:08 PM 7/27/2005
Old Jul 28, 2005 | 12:02 AM
IM ALL BOB's Avatar
regardless how old this post is. thanks for the update.. Just wondering is brian aware that the use of CRV brackets will cause a problem with rotor clearance when used with the thicker rotors? or can you still use the CRV brackets with thicker washers to cure this? thanks
Old Jul 28, 2005 | 01:47 AM
Agent_STFU's Avatar
Banned
Awesome post. Sweet pic, too
Old Jul 28, 2005 | 02:07 AM
ChewiSi's Avatar
nice set-up
Old Jul 28, 2005 | 02:21 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (ChewiSi)
Old Jul 28, 2005 | 03:26 AM
skip.two's Avatar
seems like an awesome setup, and thanks for updating. i will look into this more
Old Jul 28, 2005 | 03:41 AM
6ghatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">regardless how old this post is. thanks for the update.. Just wondering is Brian aware that the use of CRV brackets will cause a problem with rotor clearance when used with the thicker rotors? or can you still use the CRV brackets with thicker washers to cure this? thanks</TD></TR></TABLE>
Thanks.
I believe Brian is aware of the CRV bracket issue. It's not just that the CRV's mounting brackets are the wrong offset but there is not enough width to clear the rotors. If you were to use CRV calipers I would just get the ITR mounting brackets and be safe.
Boostage
Aug 10, 2008 09:39 AM
jdmekrobot
14
Mar 19, 2008 02:28 PM
euclid
Mar 28, 2003 04:17 PM
slimbo
Mar 6, 2003 02:19 PM
D-Man
Mar 4, 2002 04:48 PM
