car wont start help me please
took the timing belt off. was goin to change it but bolt was strip so couldnt not get the lower cover off. got the belt back on now car wont start. i made sure it was at tdc and had someone else check it. didnt take the intier belt off just the top. what do u think happen maybe moved a couple teeth if so how can i check that. or could it just be the main relay it has givn me some problems before like no start when its hot. NEED HELP A.S
well you probably moved the balancer belt at the bottom or like you said the a teeth of, might show tdc at top but might be off at the bottom, to check the main fuel relay just slap the side of the dash the drivers side while cranking it, see if starts if not just take it to a shop you have to get the belt done either way.. good luck
i never got to the balance shaft never loosend the tensioner so i dont c how that could of moved. a round how much does it cost to have new timing belt put on. ne one in maryland know a local shop. near jessup or laural area
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
tangb2023
Jul 9, 2003 09:17 PM
