Moonroof needs a push to open, solutions?
Old Sep 17, 2004 | 01:20 PM
Krash Enbyrn's Avatar
Default Moonroof needs a push to open, solutions?
I own a 94 Si. My mother owns a 93 Si and so does one of my friends. All of the vehicles have the same problem with the moonroofs. The driver's side of the glass is not going up. If you push it up, it works fine from there. Now I've rebuilt my motor, replaced my cables, and completely disassembled, reassembled, and lubricated the moonroof assembly, but it still has the problem. Since it seems a common problem, I was hoping someone had come up with a solution for it. I'm all out of ideas, and my roof is getting scratched
Old Sep 17, 2004 | 01:28 PM
DJ_NeX's Avatar
Default Re: Moonroof needs a push to open, solutions? (Krash Enbyrn)
try sprayin some WD40 on the rails and the little arms that push the glass up.
Old Sep 17, 2004 | 01:38 PM
Default Re: Moonroof needs a push to open, solutions? (DJ_NeX)
I'm sorry. When I said I lubricated the moonroof assembly, I meant I lubricated every single mechanical moving piece that's attached to the assembly while I was disassembling and reassembling it. Yes. Lots of fun.
Old Sep 17, 2004 | 02:04 PM
redlinetuning's Avatar
http://www.dmv.org/vehicle-tire-recalls.php
nothing on the sunroof.. could just be a defect.
Old Sep 17, 2004 | 02:50 PM
photec3's Avatar
Default Re: Moonroof needs a push to open, solutions? (redlinetuning)
mine does the same thing. I sprayed some lithium grease on the rails and it seemed to get better for a little while, then it started sticking again. If it is wicked hot out it wownt stick.
Old Jun 3, 2008 | 10:38 PM
seeeker's Avatar
Default Re: Moonroof needs a push to open, solutions? (photec3)
old thread, but just so everyone knows, it's probably getting stuck from the rubber molding sticking to the car frame as the glass rise... what i dd was put some lithium grease on the car frame, the painted sides and wahla, moon roof doesn't stick anymore.
Old Jun 3, 2008 | 11:15 PM
batallic's Avatar
wd40 no more sticking fo me
Old Jun 4, 2008 | 12:22 AM
Hanmin's Avatar
in cold weather my car does this, but in hot weathers my moonroof is full of power. A little boost doesn't hurt it, but I'll try the wd40 method and lithium grease if the wd40 doesn't work.
Old Jun 4, 2008 | 03:07 AM
d16z6_b_pirate_13's Avatar
Default Re: (Hanmin)
i have a 94 coupe and a friend has one also his sticks and mine dont dont know why
Old Jun 4, 2008 | 07:36 AM
428saleen's Avatar
Default Re: (d16z6_b_pirate_13)
I have 94 hatchback, Mine sticks as well, just give it a push and its fine. I'm gonna try the wd40 on the rails though!
ZenDog73
Mar 1, 2013 05:00 PM
ahtublao
Jan 19, 2010 05:37 PM
OoHiTzToMMy
10
Oct 16, 2003 06:37 AM
dyases
Jan 9, 2003 01:43 PM
CivicHB-Si
Jul 21, 2002 09:24 AM
