what code is this?
http://tech.hybridgarage.com/tech/codes.html
did you check more then once? are you doing it right??^^^ there is a list of all the codes
here's also a list of codes.
https://honda-tech.com/zerothread?id=682412
this is literally the first thread in the forum. next time search, or at least look.
i know that.. whats wierd is the code
it blinks 4 times slowly and then 2 times quickly
42 right??? but there is no cel 42 is there? cant find it on the code list
i checked it 3 times.
i put a paper clip in service connector on passenger side clikc the ignition to on not starting the car.
the check engine light blinks 4 times slowly and then 2 times quickly and then stays lit.
is it suppose to cycle?
when im checking for codes i jump tjhe connection switch and then turn ignition on to the on position and read the cel code 42 but it doesnt repeat itself the cel just stays on is that right for my car or is it suppose to repeat?? thanks
